1996 XJ6
Old Feb 18, 2022 | 09:33 AM
Richyb8's Avatar
Default 1996 XJ6
Is this a good year? There is one I could get for 4 K that needs nothing. It is a 9 of 10.
I am tall, will I fit in it. 6’5 and 290..
Old Feb 18, 2022 | 09:58 AM
Welcome to the forums Richyb8,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X300 forum. Members here with this same model will be able to help.
If you go ahead to buy it and plan on sticking around, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 19, 2022 | 02:04 AM
SleekJag12's Avatar
Yes Richyb8, this is a good year. That car is only 472 later than the 96 XJ6 I owned.
"Needs nothing" is not really believable for a 26 year old Jaguar (or any car that age?). Just from that bad picture I can see that it needs the headliner re-glued. It seems to have an extreme lean to the right! Suspension sag is common.
Regardless, you will be a tight fit in that car. Seat at max down and back. You might fit ok but will want to actually try before buying.
Old Feb 19, 2022 | 09:19 AM
Doug's Avatar
Richard is right. These are great cars but I can virtually promise it needs work. This doesn't necessarily mean you shouldn't buy it. But, be aware and beware !
There's a buyers guide in the "How To" section above, in the sticky threads.
Old Feb 19, 2022 | 09:20 AM
katar83's Avatar
Realistically looks great from the pic, except maybe for headlining. Normally, especially with this car colour you'll see bit of bubbling underneath the rear light where back panel joins rear wings. This looks perfect there but as always first thing to go on x300 is front of the sill from underneath the car where it joins to toe board. If it's ok there it's ok everywhere else and rust is always worst and most expensive to fix so if this is solid underneath, price is reasonable I'd say if you like it.
I'm 6ft3 and I fit no issues but at 6.5 I'd say you won't fit if it's sunroof model and just about fit if it isn't, with seat at the bottom and bit to the back and noone will be able to seat behind you unless a baby in its own seat.
Ideally you'd LWB but I don't think they sold them in US?
Old Feb 19, 2022 | 09:29 AM
Doug's Avatar
As I recall all USA market X300s SWB for 1995 model year. For 1996-97 the LWB models were available. But the extra length was all aft of the driver!
Old Feb 20, 2022 | 09:35 AM
aholbro1's Avatar
All mine are fitted with sunroof. The 96 VDP (LWB) was originally obtained for our youngest lad in high school and he was about 6'1" or so. Took it away to college and got it T-Boned by an F150, so it became the parts car and we sent him back with one of the X202's. He subsequently sprouted to 6'5" and, owing to the inherent unreliability of the X202's, I had to send him back to school for a couple of months in an X300. He doesn't "fit" in the classic sense. I'm 5'8" probably pushing 5'7" now as I believe I'm shrinking in my old age, and I drive it with the seat all the way aft. He added a steep recline to that in order to drive it. I suppose as long as you have a wingspan befitting your height or longer, and don't mind driving whilst laying down, you'll fit. FWIW, he drove his sister's 2020 RAV4 and pronounced that's what he seeks post-secondary education. "I forgot how nice it is to be able to sit up and drive, not banging your head against the roof!"
Old Feb 20, 2022 | 12:03 PM
Parker 7's Avatar
The SWB will have 36 inches on the rear door lower glass edge
The LWB will has 6 inches extra
The extra is all aft of the front seat mounting
The SWB / LWB will be in the VIN # as the 7th # this example being _ so it will be ( something not right )
Should be the letter after X for USA model
Mine is a 1 and a USA model and SWB
According to Doug in post # 14 of this thread there is a separate VIN chart for USA models
VIN DECODE - Jaguar lookup tables - Jaguar Forums - Jaguar Enthusiasts Forum
Click on image twice to magnify
Old Feb 27, 2022 | 01:36 PM
DangerPete's Avatar
I myself am 6 ft 4 and I fit into X300 without the least problem. Seats are not too large, try out if you can feel comfortable.
Choppa
Aug 9, 2019 09:31 AM
tmill051
Nov 12, 2011 12:09 PM
racerBVD
Feb 19, 2009 03:36 PM
