1996 xj6 4.0l starts in every gear no reverse
Old Jul 24, 2023 | 06:36 PM
Richardbussiere's Avatar
Default 1996 xj6 4.0l starts in every gear no reverse
Hey everyone kinda new here but seem to be having a problem with my 1996 xj6 .... long story short just purchased it a month ago for a steal as battery was dead and owner couldn't get in the car .. popped a battery in after unfortunately drilling behind the plate and fired right up. Put 2500 km on the car over the last month and one day car was stiff to change gears and when it did change car wouldn't leave first gear and now no reverse ... also starts in every gear. Thinking it has something to do with the rotary neutral switch but unsure if that would cause me to lose reverse ??? Anyone have any ideas ??
Old Jul 24, 2023 | 11:36 PM
Parker 7's Avatar
With key in a certain position, I can't recall by slightly moving the shift lever out of the park gate you will feel a click on the ignition key barrel from the key barrel lock solenoid not in park switch system , so this directly test the not in park switch
There is the importance of replacing the not in park switch with the proper normal open or normal closed
There is also a shift lever solenoid system
Relays involved
Pic coming
See page 20 of the upcoming Doc
X300 1996 LWB.pdf (jagrepair.com)
The transmission rotory switch is used as a enable or through path to allow the starter solenoid relay to close
It has an adjustment but I wouldn't adjust it just yet or lose what you have
It has some delicate wiper fingers inside that can be cleaned with a pencil eraser
Rfurzer
Jul 19, 2021 09:46 PM
Shotcaller0074
General Tech Help
May 31, 2020 12:43 PM
mikega
Sep 3, 2017 09:00 AM
sowyers
Feb 21, 2014 10:51 AM
