1996 XJ6 Clunking Noise
Old Dec 7, 2009 | 04:44 AM
m0t0rm0uth's Avatar
Mechanically speaking, the "front end of the car" encompasses a WHOLE lot of stuff. If the car is doing it while in park, it's most certainly in the engine (presumably nothing is loose in the engine compartment). I would have a friend/cohort give the engine some revs while you're under the bonnet, and see if you can narrow where the sound is coming from (a loose metal thing banging around aimlessly or if it's coming from within the engine itself, and, if so, top end or bottom end, etc).
Is the clunking light and tight? Meaning light pinging and more of a drum roll, or is it low and randomly beating? If it's the former, it may be something as simple as a loose tappet under the valve covers. If it's the latter, it could lead to an engine overhaul.
Old Dec 8, 2009 | 12:04 PM
Hi Welcome,
First get that oil changed now (car standing a year and you don't when it was done before that.)
Second do not go anywhere near full throttle until you have isolated and identified the noise you are hearing.
If it is a light clickety rattle type of noise it is likely to come from the top end of the engine.
If it is more of a heavy loud rapid knocking sound that increases with revs, it is likely to come from the bottom of the engine. If it is very bad it will deafen you, especially going up hill. (sounds like a jack hammer)
You say that your car has been standing for a year, so therefore no oil has been pumped up to the top end of the engine.
Your upper timing chain tensioner will have been dry and could well be sticking, causing a rattley chain. When you have changed the oil + filter and you start the car DO NOT REV IT allow the oil pump to do its work in getting the oil up there.
You may notice that the noise dies away as the car comes up to temperature, plan on eventually changing the tensioner.
You could also have sticky 'valve lifters' I think you call them. Giving similar symptoms as above, again folow the same gentle starting procedure.
Treat the thing gently until you know what you are dealing with.
Changing the plugs etc, probably a good idea whether or not, but don't expect miracles.
You can fill your rear end with fluid, but I doubt it will help the engine.
Razor
Aug 28, 2019 08:34 PM
Terry007
Sep 24, 2015 10:36 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
raulan
Sep 10, 2015 12:43 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
