1996 XJ6 trans problem
Old Sep 12, 2017 | 03:10 PM
Jeddington's Avatar
Default 1996 XJ6 trans problem
I have a 1996 xj6 a couple days ago had a coolant hose blow and now its fixed . but know trans has issues wont shift and a. Message on dash says fluid checked it full all fuses good . never any trans issues prior to ruptured hose . Help
Old Sep 13, 2017 | 12:03 AM
Firstly, welcome to the Forums.
When time permits, please do an Intro in the New Members Area.
I will assume you have a 4ltr car, with the electronic transmission, as apposed to the 3.2ltr with the non-electronic transmission.
Sounds like the coolant from that rupture has found its way into a sensor/connector somewhere close by. Coolant should have left a stain, so a tad easier to trace out.
Your car is known as an X300, and one of the Moderators will shift this when they catch up, but maybe a reask in that Tech Section by yourself, might get a quicker response.
Old Sep 13, 2017 | 12:18 PM
Jeddington's Avatar
Isnt trans supposed to be serviced. .fluid changed IHave checked relays and fuses?
Old Sep 13, 2017 | 03:09 PM
Originally Posted by Jeddington
I have a 1996 xj6 ...... Help
Welcome to the forum Jeddington,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Old Sep 13, 2017 | 09:38 PM
aholbro1's Avatar
"Won't shift?"
You are leaving us out in the cold, here Jeddington.
Do you mean the shifter is locked in place in the J-gate? There is a solenoid that is supposed to fire when you put your foot to the brake pedal, but the microswitches can get hissy and that stops working. Work-around is to remove the torx screw at the top-left corner of the J-gate and stick an object down in that hole (such as a philips screwdriver) to release it until you get it sorted. Much written here on that issue that will be revealed in a search.
Or do you mean it goes into one gear, say 1st, and then never shifts out of that? If so, does reverse work?
Also, it would be helpful to know if you have the 4.0L or the 3.2L. Your location would help resolve that issue if it happens you are here in the states, as we didn't get the 3.2L, but neither do you list a location. Help us help you.
Old Sep 13, 2017 | 11:24 PM
Lady Penelope's Avatar
There is a round electrical connector on the left aft side that may have got some sort of contamination . You can pull it and flush with some contact cleaner without jacking the car . The separate transmission ECU lays flat on the bottom of the passenger seat opening {L or R ) and has a long connector easy to get to and clean . Bosch unit label .
Digital Will
Feb 21, 2026 05:58 PM
JimC64
Sep 22, 2025 02:52 PM
Jan 3, 2012 12:52 PM
May 14, 2006 12:29 AM
