1996 XJR/6 (x306) Which variant of the steering rack do I have?
Old Jul 29, 2019 | 02:02 PM
juha_teuvonnen's Avatar
Default 1996 XJR/6 (x306) Which variant of the steering rack do I have?
My steering rack is leaking and I am planning to replace it with a rebuilt unit. Based on my research it appears that there are different variants of the steering rack? Some say that supercharged XJR has a different ratio from normally aspirated? Also, the site where I was trying to order it lists EVO (speed sensitive variable assist) and non-EVO versions. How can I tell which one I got?
Any pointers to rebuild kits and/or instructions would be greatly appreciated as well.
Old Jul 29, 2019 | 03:40 PM
Lady Penelope's Avatar
On the left side of the left side foot well for a LHD american version there is a steering control module if you have variable steering
It's under the small cover
Although I have not done it the outer seals can be replaced without removing the steering rack
But the 90 degree ball joint rod end must be removed
https://www.jaguarclassicparts.com/u...ack-and-pinion
By changing the fluid many times as a drain / refresh method the seals soften and seal better
http://jenniskens.livedsl.nl/Technic...F%20BMW%20.pdf
Oubadah
Mar 17, 2023 02:22 AM
amcdonal86
Jan 24, 2014 01:33 AM
Christian 96 XJR
Oct 18, 2012 10:27 AM
Plum
XJ40 ( XJ81 )
Jul 31, 2010 04:07 AM
tianma_jaguar
Jan 28, 2010 02:30 AM
