1997 XJ6 steers left when I accelerate!
When I accelerate in my 1997 XJ6, the car pulls to the LEFT ( or VEERS, or steers, left ) as if the REAR is steering the car..............and then it pulls ( or VEERS, or steers ) right when I let off the gas................any ideas?.......I have not looked at the rear suspension yet--it does not seem to be a front-end problem............ I have found that this forum is a good place to start before troubleshooting any problem........Has anybody experienced this exact issue?
Thanks guys for the help...............when i jacked-up the jag's rear end , the problem was OBVIOUSLY a TOTALLY worn-out left rear wheel bearing.............so bad that the hub, aluminum upright / bearing carrier, stub axle, and brake rotor were all damaged............the caliper was really the only thing holding the wheel on!...........but, strangely, the only noise was a SLIGHT worn wheel bearing noise.............retail on those parts was $2800............everything USED at ENGLSH-SWEDISH CAR SPARES in georgia was $350 delivered!............sounds good to me...........thanks again........
rusty37
Apr 5, 2020 07:40 PM
