1997 XJ6 steers left when I accelerate!
Old Dec 21, 2012 | 03:05 PM
zero250's Avatar
Default 1997 XJ6 steers left when I accelerate!
When I accelerate in my 1997 XJ6, the car pulls to the LEFT ( or VEERS, or steers, left ) as if the REAR is steering the car..............and then it pulls ( or VEERS, or steers ) right when I let off the gas................any ideas?.......I have not looked at the rear suspension yet--it does not seem to be a front-end problem............ I have found that this forum is a good place to start before troubleshooting any problem........Has anybody experienced this exact issue?
Old Dec 21, 2012 | 04:43 PM
sparkenzap's Avatar
I would get under the left rear end and have a look SOON. Before the suspension falls off.
Old Dec 21, 2012 | 08:41 PM
Suede's Avatar
Unless your regular commute is a lap around Talladega, I too would have an immediate look at those rear end linkages.
Old Jan 3, 2013 | 10:54 PM
aldol's Avatar
if you hear loud bangs when u hit potholes, then your shock bushings are probably gone rentirely ( they are made of effing FOAM can u believe that?)
Old Jan 7, 2013 | 12:50 PM
zero250's Avatar
Thanks guys for the help...............when i jacked-up the jag's rear end , the problem was OBVIOUSLY a TOTALLY worn-out left rear wheel bearing.............so bad that the hub, aluminum upright / bearing carrier, stub axle, and brake rotor were all damaged............the caliper was really the only thing holding the wheel on!...........but, strangely, the only noise was a SLIGHT worn wheel bearing noise.............retail on those parts was $2800............everything USED at ENGLSH-SWEDISH CAR SPARES in georgia was $350 delivered!............sounds good to me...........thanks again........
Kevin Burnaby
Jun 28, 2020 08:04 AM
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
XFR_Gold
Sep 2, 2015 12:24 PM
