1997 XJR driver seat, how to replace module?
Old Jul 12, 2016 | 11:27 PM
juha_teuvonnen's Avatar
Default 1997 XJR driver seat, how to replace module?
1997 XJR seat does not move forward or back. I was told that it is most likely the module. Where is it located, and how can I get to it, provided the seat does not move. Thanks.
Old Jul 14, 2016 | 07:15 PM
al_roethlisberger's Avatar
It is right up under the seat toward the front, and as I recall it is held in with one screw at one end that once removed allows the module to just slip out.
I think you have to unbolt the front of the seat, and loosen the rear, so you can lift the front to get a stubby screw driver up under the seat to unscrew the screw.
And of course you have to unclip/unplug the two harness connectors.
JohnXJR6
May 18, 2016 12:32 PM
JTsmks
Apr 29, 2016 02:47 PM
JTsmks
Apr 27, 2016 12:52 PM
skubeedoo
Apr 21, 2016 01:40 PM
pilot435
Apr 16, 2016 12:53 PM
