400.000 km X300 XJ6
Old Jan 24, 2023 | 03:11 AM
Fghhhz's Avatar
Default 400.000 km X300 XJ6
Hello
I'm looking to buy a XJ6 3.2 Manual from 1997 with 400.00km!
Went to see the car yesterday and a few issues came up.
The car runs fine, very smooth, no rattles, no smoke or vibration. Starts right up from cold, no warning lights.
The problem I found is the clucht stuck to the floor. Searched online and clutch slave or master cylinders are virtualy non existent or very expensive. Theres also a rebuild kit, but didint find a clutch for sale for example
On the inside only found a window very slow going up.
My question if everything in this car will be this hard or expensive to find? I have a bunch of old Alfas anda even for the more rare like the v6´s parts are easier and cheaper to find. Should I try to find a autobox one?
The car is the following:
https://www.standvirtual.com/anuncio...-ID8PnX3K.html
Old Jan 24, 2023 | 11:05 AM
labcoatguy's Avatar
Wow, that looks like an extremely high price for a car with such high mileage, even if it is a rare specification. With regard to clutch masters, you can use the more commonly available XJ40 version, just make sure the reservoir is on the correct side (see my thread at https://www.jaguarforums.com/forum/x...ptions-175684/ for part numbers). Unfortunately parts for the X300 are becoming quite hard to find, and the aftermarket is not very strong compared to even your old Alfas, so if you can't find parts from places like David Manners or SNG Barrett, they are unlikely to be available elsewhere.
Old Jan 24, 2023 | 11:25 AM
Fghhhz's Avatar
Thanks for your reply
Regarding the price, it is the cheapest in the country by far. A used one with half the milage would be priced 15.000 euros or higher.
I'm very tempted to buy the car, love the exterior and interior colours.
The dealer said they would fix the clutch before seling, my take on that is that they will not be able to do it.
I might change the master cylinder at home or any other mecanical parts as I do most of my cars maintenance myself. Not sure if I dont buy It has it is and throw in a cheaky offer.
Any other thougths in what I shoulf be looking at?
Old Jan 24, 2023 | 11:33 AM
Parker 7's Avatar
Listen for rear differential output bearing noise
Editing
See section 7.1 of the 2nd pdf of the following thread in post # 4
Repair Manual - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jan 25, 2023 | 03:19 AM
Fghhhz's Avatar
Editing
Very helpfull!
Old Jan 25, 2023 | 06:08 AM
xalty's Avatar
99% of the parts you need can be found you just need google skills. new clutch and flywheel is avaliable just type aj16 clutch into ebay uk
Old Jan 25, 2023 | 07:01 AM
Fghhhz's Avatar
Thanks.
I've found for sale single mass conversion kits. Do this cars come with a dual mass from factory?
The window motors are available new, or only from the scrapyard?
Old Jan 25, 2023 | 07:23 AM
xalty's Avatar
Originally Posted by Fghhhz
Thanks.
yes factory is dual mass which is why you’re forced to convert
window motors and regulators are dirt cheap used they don’t break like 20 bucks at most. auto reserve jaguar will almost always have the part you need
Old Jan 25, 2023 | 06:50 PM
Parker 7's Avatar
I had a slow / failing window motor and you can pull out the 2 motor drive wires and run the widow with a battery charger up and down
The 2 drive wires are at a hole in the front of the door ,
turned out the connector was loose on the pins lock bar
In the end the control switch must be held to the up position for a moment of time and then the controller learns the full up position
Old Jan 25, 2023 | 07:54 PM
Bill Mac's Avatar
Spray the window tracks with a proprietary silicon spray designed for zippers and windows.
Works a charm.
Old Jan 26, 2023 | 03:38 AM
someguywithajag's Avatar
Thanks.
Single mass for the naturally aspirated ones. Dual mass for the supercharged ones. Can swap the single mass on the dual mass.
Old Jan 26, 2023 | 11:25 AM
xalty's Avatar
all 3.2/4.0s after late 92 are dmf
Old Jan 26, 2023 | 08:08 PM
Mea culpa. Interesting...
labcoatguy
Jan 9, 2022 04:43 PM
Tjhark
May 9, 2017 11:47 AM
Paulofvfreitas
Feb 21, 2015 02:27 PM
FireCrow
Jun 26, 2013 08:54 AM
