'95 XJ6 177k mi - 'clutch?' slip at 3000rpm
Old Mar 17, 2008 | 06:57 PM
jag_genius's Avatar
Default RE: '95 XJ6 177k mi - 'clutch?' slip at 3000rpm
good luck with the clock display.. about $450 for that one piece.. and the skull light is a trani light.. and if the diff is pissing i wud get that fixed right away. and cant remember the steering and seat shud go back.. on 98 i know for sure,, but xj6 maybe will have to check.
Old Mar 18, 2008 | 12:39 PM
ken@britishparts.com's Avatar
The clock is no big deal. It loses contact with the face. Slip a business card behind it to shim it.
Old Apr 16, 2008 | 06:52 PM
azureyes's Avatar
Re the steering wheel and seat pull back...this is standard on my car which I really like. When you put they key in, it will return to the driving position you've previouslyl set on the memory buttons. When removing the key seat/steering wheel will move out of the way to exit. To stop the motion of wheel and seat, simply step on the brake pedel or touch the seat adjustment switches that will stop the seat....steering wheel there is a switch on the steering column you can move. This is from my manual page 25. Hope this helps. L
ahunt4
Sep 19, 2015 06:46 AM
Unhingd
Sep 18, 2015 07:00 PM
Phil G.
Sep 12, 2015 07:42 AM
Greg Reed
Sep 11, 2015 08:41 PM
XFR_Gold
Sep 2, 2015 12:24 PM
