95 XJ6 Rhythmic Noise From Front When Rolling
Old Dec 18, 2016 | 02:03 AM
Kopi's Avatar
Default 95 XJ6 Rhythmic Noise From Front When Rolling
Hi all, appreciate some help here.
First off, I have done a full suspension refresh just months ago. Parts that I have replaced are listed in my post. https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/xj6-suspension-overhaul-fitting-rear-sway-bars-monostrut-163427/#post1472376
Over the past several days I've been hearing a rhythmic soft knocking noise from the front that is audible when the car is at low speed (30-40kmph) AND when there is some steering input (not a full turn, just a slight left steering input). Actually if I give a little steering input on a straight, the rhythmic gentle knocking manifests as well.
Any suggestions please? Lug nuts, wheel alignment etc has been checked.
Thanks!
Old Dec 18, 2016 | 02:16 AM
Doug's Avatar
My first guess is loose and/or worn front wheel bearings
Old Dec 18, 2016 | 04:10 AM
Kopi's Avatar
Thanks doug. Sorry I might've missed that on the list in the post but front wheel bearings are brand new. And I did the whole tug and pull on the wheel test, seems ok.
Old Dec 18, 2016 | 10:01 AM
Doug's Avatar
IMO....Tug 'em again, just for the heck of it. Only takes a minute and costs nothing.
If they came out of adjustment a bit, it certainly wouldn't be the first time...particularly with the troublesome design (and often troublesome installation) of the hub seal on the X300....especially if new seals were used.
Check for a loose caliper as well, or a brake pad loose in the caliper.
Old Dec 18, 2016 | 02:43 PM
b1mcp's Avatar
What's the frequency of the knock. Does it change with engine speed or road speed or neither?
If Doug's suggestion doesn't pan out then as a long shot - if the knock becomes apparent with slight steering input I'd check the high pressure hose (and also the rack) is secured properly and not knocking against something as a result of steering pump pulses.
Old Dec 22, 2016 | 10:51 AM
littlelic69's Avatar
I had a similar experience with my Daimler after it had been re-painted. The road wheel nuts or lugnuts were finger tight.
Old Jan 13, 2017 | 06:49 AM
Kopi's Avatar
Thought i should close off this one.
The noise was actually coming from a loose titanium stud on my 18" milans (probably stripped the threads slightly but i guess thats a problem for another day)
Thanks to the suggestions though, at least i know my bearings are in good condition
