96 4.0 sovereign idle problem
Old Sep 16, 2014 | 05:47 AM
jancar's Avatar
Default 96 4.0 sovereign idle problem
hi,i have a 96 4.0 sovereign straight 6 and it has been sitting for 2 years,i attempted to start it yesterday and the revs went upto around 4000rpm and stayed there,what should i be looking for to cure this,any help very much appreciated! dan
Old Sep 16, 2014 | 12:11 PM
aholbro1's Avatar
Welcome to the forum, Dan.
Please drop by the new member's section and introduce yourself so a mod can take notice and upgrade you to full status when you've completed all the prerequisites.
Meanwhile, I reckon we should all pause and give thanks that yours lit after 2 years! https://www.jaguarforums.com/forum/x...ngines-120221/
Normally, sticky throttle plate is at idle and folks break the cable or mechanism trying to get above idle. Just a guess but maybe you have a gunked-up throttle body and it is stuck partially open?
I'd recommend pulling the throttle body and cleaning it thoroughly, taking care not to ruin your TPS in the process. Search throttle body for some how-to threads or maybe it is in the stickies. Also, drain & replace that aged fuel before running it again or you'll likely face a significant fuel system cleanup, possibly including injectors. Also time for a complete fluid renewal project: fuel, oil, coolant. But as to fast-idle, I'd look at the throttle body, then maybe the spring (normally will come down after a kick or two if it's the spring problem.) Maybe IACV or TPS calibration. Others will chime in with better ideas...
Maybe something useful: https://www.jaguarforums.com/forum/x...e-down-113680/
Old Sep 16, 2014 | 01:08 PM
Vee's Avatar
Vee
I will vote TPS calibration. I'd even go so far as to put a ten dollar bill on that...
Thang Nguyen
Oct 12, 2015 01:25 AM
Dicque
Sep 19, 2015 12:53 PM
Harry Dredge
Sep 5, 2015 02:44 AM
Dicque
Sep 4, 2015 12:50 PM
Bowman
Sep 3, 2015 03:17 PM
