96 xj12 gearing.
Old Apr 16, 2010 | 09:11 AM
andrew4566's Avatar
Default 96 xj12 gearing.
My XJ12 has such long legs and with the price of gas I dont see taking it on the open road too often.
I could imagine that the power would be quite thrilling with a higher gear ratio?
I dont know what it is stock but is this a swap that is ever done? what would be the downside besides sub 10mpg?
-Andy
Old Apr 17, 2010 | 08:44 AM
Doug's Avatar
It probably has the 3.58 ratio. You can search around for the 3.77 diff.
I went from a 3.27 to a 3.58 in my XJR and I dropped exactly 1 mpg at highway speed. The increase in performance was worth it. Not a night-n-day difference, but a definite improvement
Old Apr 17, 2010 | 10:02 AM
andrew4566's Avatar
Is it necessary to replace the entire carrier as a unit or can the gears be swapped?
Is it cheaper/easier to swap the carrier?
any source suggestions?
Old Apr 17, 2010 | 07:41 PM
Doug's Avatar
You can probably just swap gears. I'm not positive. I got a rebuilt unit from a liquidator on Ebay. It wasn't really my plan to change ratios but my original diff failed and this 3.58 unit came along at a great price.
Motorcars Ltd, can fix you up, I'm sure
Forcedair1
Feb 19, 2020 01:51 PM
MILOU13
Nov 25, 2015 02:39 AM
philwarner
Sep 5, 2015 10:05 AM
