97 Jaguar XJ6 beeping noise
Subscribe
Jun 2, 2016 | 08:30 AM
Hey guys, first off I have just bought a 97 jaguar xj6 v6 4.0 I love it and everything about it. I have been fixing a couple things here and there. My next fix is just a new gas cap as it turns my check engine light on cause it's old and loose. It came back on today which I read with my decoder but however today is the first time I ever turned the car on and a loud beeping about 5 or so times came on and went off. Any ideas what it could be cause I have nothing on my decoder bit then again it's a real fancy one do I'm not sure. Thanks everyone for any help.
Reply 0
Jun 2, 2016 | 12:44 PM
Welcome to the forum Cbell89,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
XJ6 v6. Replacement engine?
Reply 0
Jun 2, 2016 | 01:07 PM
Original motor
Thank you I do believe it's the original motor.
Reply 0
Jun 2, 2016 | 01:43 PM
Welcome to the forum...
That is most likely your ICE head unit telling you to clean the tape workings, or lube the aerial. Take a look at the radio display while the beeping is going on.
Reply 0
Jun 2, 2016 | 01:46 PM
Thank you I have been trying to get to do it again all day but nothing. But I did notice is when it was beeping there was no radio playing until it stopped and then the radio came on
Reply 0
Jun 2, 2016 | 02:10 PM
It could be the "AC Temp sender" (I assume that's what it's called) unplugged behind the drivers side knee panel trim.
The air con would show "er" as well though. Worth a look, could be an easy fix.
Reply 0
Jun 2, 2016 | 02:17 PM
Awesome I'll check it out thank you. I'll be back if not
Reply 0
Jun 2, 2016 | 05:11 PM
Yep, bet it is the "clean aerial" alert
I betcha money that's it ....threw me off too when it first happened to me as it is a pretty annoying, urgent and loud beeping that then just goes away without a trace
But now it's done it a few times and I expect it
https://www.jaguarforums.com/forum/x...-radio-121628/
Reply 0
Jun 2, 2016 | 09:32 PM
It's not a "lube Ariel" but IIRC its "clean Ariel" and the reason you haven't heard it again is because it isn't that the Ariel is dirty it's just that it comes up based on a time cycle. I told the new owners of my X300 today not to panic the first time they hear it nor assume the Ariel needs cleaning, it's just a reminder based on time usage.
Reply 0
Jun 3, 2016 | 02:44 AM
Quote: Thank you I do believe it's the original motor.
Then it's an inline 6 cylinder, not a v6.
Reply 0
Jun 3, 2016 | 08:51 AM
Quote: It's not a "lube Ariel" but IIRC its "clean Ariel" and the reason you haven't heard it again is because it isn't that the Ariel is dirty it's just that it comes up based on a time cycle.
Yeah, but if he doesn't lube it with a bit of teflon or similar after cleaning it will become "replace aerial" when it gets stiff and the motor breaks the little plastic rack that runs it up and down.
That feature can be turned off by a certain button press sequence on the head unit that I don't recall.
Reply 0
Subscribe
Currently Active Users (1)
