97 VDP: Can bad coolant temp sensor prevent heater from getting hot?
Old Dec 20, 2010 | 09:22 PM
gbmtkj's Avatar
Post 97 VDP: Can bad coolant temp sensor prevent heater from getting hot?
Only getting minimal heat.
I have not observed the heater water pump (small black cylinder?) running, even when fully warmed up.
I don’t see voltage at its input.
Coolant temp needle never leaves full left (cold) position.
Shorting the single-blade temp sensor wire (at themostat housing) to ground causes needle to tick up, ~one tick/second.
I assume that the little pump does not run until a certain temp is reached?
Is the sensor the likely culprit, or could a thermostat problem keep heat from getting to the sensor, even when fully warmed up?
What’s that other sensor (2-pin) in about the same area, near the thermostat housing? Should I suspect it?
Thanks,
gbmtkj
Old Dec 20, 2010 | 11:20 PM
Doug's Avatar
I'm pretty sure the pump runs at all times but at very least it should run when the system is set to give heat.
Replace your thermostat and your temp gauge will come up to "N"
Old Dec 21, 2010 | 09:28 AM
Drew's Avatar
Check the voltage at the aux pump. Some people have found that the fuse is blown.
Old Dec 21, 2010 | 04:39 PM
Simprof's Avatar
If you can check the upper and lower hoses feeding the Rad if the temp are the same then the thermostat is faulty..
Old Jan 5, 2011 | 12:10 AM
gbmtkj's Avatar
Smile THANKS! New thermostat solved two problems.
Thanks to all for the suggestions.
Doug, the problem did turn out to be the thermostat.
After replacing it and driving about 3 minutes, the temp needle left 'C' for the first time, and marched right up to 'N'.
AND, the heater makes good heat now. I can't leave it on '80' anymore!
Thanks,
gbmtkj
Old Jan 5, 2011 | 04:17 AM
Cadillac's Avatar
Thanks for your feedback , those will be useful if one of our members tackle with same problem
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
user 652867429824
Sep 5, 2015 12:53 PM
KarimPA
Sep 3, 2015 07:32 PM
Bcrary3
Sep 3, 2015 03:48 PM
