97 XJR 4.0 Battery warning indicator
Old Jun 29, 2017 | 06:23 PM
jdenglish1944's Avatar
Default 97 XJR 4.0 Battery warning indicator
Breaking News! This just in! Another gremlin surfaces. The battery is fully charged. The alternator puts out 14.58 volts measured at the battery. Does it know something that I don't?
Old Jun 30, 2017 | 08:53 PM
Lady Penelope's Avatar
The B+ post ( the big one ) on the alternator after the voltage regulator should read about 13.5 volt . You are reading the same thing at the B+ terminal at the battery above the battery storage voltage . Looks like a voltage regulator mounted on the alternator . 120 amp not cheap vs. normal 90 amp . You can have the auto parts store check this on car for free in 5 minutes . If not addressed it will cook your battery . Keep in mind the current state of the industry is they put out junk " reconditioned " alternators that can fail before you get out of the door . Have them spin it up first on there machine before you go through the trouble of replacing it with a bad out of stock unit . Then it may fail the next day after you replace it . Recommend just replace the " new " regulator to save some money for the rest of the alternator is a very robust design . The center terminal screw to get the bushing ring off may be welded or stuck so it may hang you up . Plan accordingly . Check your brush wear / mileage . The pivot bolt bushings toward the engine block were pinching on mine and had to file the shoulder of the bushings down for reinstall clearance . May have to use a large screwdriver to free this up to get it out . Can remove the alternator unit from the top . Don't forget the smaller control wires .
Old Jul 11, 2017 | 05:55 PM
Went to the local CarQuest store for an in car alternator/battery test. No Joy. Electrical system OK. Red battery dash light remains on and the Trac fail and Anti-lock fail have joined the light show. I don't think they are related. The Trac/Anti-lock warnings have been intermittent for years. Other than that everything running fine.
Old Jul 12, 2017 | 12:33 AM
I'll get with you in the morning with the 3 annoying display lights Ref. wiring schematic and practical things .
Thanks , Parker
Old Jul 14, 2017 | 06:42 AM
snowball's Avatar
Gremlin struck last night out of the blue on my 1995 XJR, battery light came on, volt gauge when to half way normal 10.5 - 11 V. I turned off AC, radio and lights to save battery but no difference in gauge, so it wasn't the belt ( which it wasn't) It sounds like the voltage regulator? What do you think where should I start?
Snowball
Old Jul 14, 2017 | 12:44 PM
Snowball , is it a true voltage problem or an indication problem ? Jdenglish1944 is a indication . The alarm sounder will sometime short out and is tied into the regulator . You can remove it's connector behind the right headlight down low with connector pointing up . There are some other item's I'll look up . Did you get rain during the anomaly ?
Old Jul 15, 2017 | 05:48 AM
snowball's Avatar
Wasn't raining when light came on, but had rained early in the day and I was out in the car.
Snowball
Old Jul 15, 2017 | 10:16 AM
Snowball , did you have to recharge the battery in order to get the battery up and fully charged ? This splits the problem in half .
Old Jul 16, 2017 | 06:03 AM
snowball's Avatar
Sorry I will do that now and let you know.
Snowball
Old Jul 16, 2017 | 12:35 PM
I'll break down this print later in the day for there is more involved then what it shows .
Attached Thumbnails 97 XJR 4.0 Battery warning indicator-jaguar-alt-np2100406_1.jpg   97 XJR 4.0 Battery warning indicator-jaguar-alternator-untitled.png
Old Jul 17, 2017 | 07:11 AM
snowball's Avatar
Charged battery up , problem remains Gauge at 11 volts battery light on as soon as you turn on ignition. Found sounder wiring jacket seems to be facing back toward engine compartment, should I disconnect the jack? I do have parts car as well.
Snowball
Old Jul 17, 2017 | 10:05 AM
Yes , just disconnect sounder wires for now and look at gauge .
Old Jul 18, 2017 | 04:57 AM
Work in progress . First draft . Watch for edit
Attached Thumbnails 97 XJR 4.0 Battery warning indicator-x300-generator-wires-untitled.png
Old Jul 18, 2017 | 08:01 AM
snowball's Avatar
Disconnect sounder, no difference in gauge or battery light How should I check altenator output
Snowball
Old Jul 18, 2017 | 12:42 PM
duplicate post
Old Jul 18, 2017 | 12:53 PM
On the B+ terminal ( large wire ) it should read 13.8 to 14.5 volts to ground which is above the fully charged battery of 12.77 to ground . Running pulleys and such so be carefull . No need to remove terminal connection just scoot insulation boot back
.http://tidewaterfleetsupply.com/Delc...leshooting.pdf
Old Jul 22, 2017 | 12:46 PM
120 Amp voltage regulator with monitor Denso # IN435 or Jaguar # JLM-11144 replaces DENSO # 126000-1200
Mine was consumed by a backwards battery hookup
Also used on: ISUZU STYLUS 1992-93, JAGUAR 1993-1997, DODGE COLT 1991-92, ASTRO, IMPULSE, GEO STORM 1996-2000 Asuna (1993-1993) , Geo (1990-1993) , Isuzu (1990-1993)
https://www.ebay.com/sch/i.html?_fro...-1200&_sacat=0
VOLTAGE REGULATOR JAGUAR VANDEN PLAS XJ12 XJ6 XJR XJS 1992-1996 | eBay
Old Jul 27, 2017 | 06:07 AM
snowball's Avatar
New alternator solved the problem, Thanks for all your help.
Snowball
