'97 XJR trunk woes...
Old Sep 9, 2008 | 01:59 PM
hlgeorge's Avatar
Default RE: '97 XJR trunk woes...
Reboot the car. Remove the + battery cable from the battery for a few minutes. Touch the + cable to the - battery post for a second to remove any static electricity. Reconnect the + cable to the + battery post. Now reprogram everything. For key fob, check here:
Make sure it has a good battery.
http://www.coventrywest.com/Jaguar/t...pofmonth11.htm
Old Sep 9, 2008 | 11:27 PM
kraziegreggz's Avatar
Here's a tip that worked for me just yesterday. Before my trunk ('95 XJ6) would never open using the key; only the cockpit button or the trunk release button on my aftermarket remote alarm system. Gave me a problem whenever the battery died. Then I squirted some DW-40 (the one with the convenient straw) into the key hole and after 30 min-1 hour it opened using the key. Try that and let me know how it turns out.
Otherwise I always jump started it from the hood by attaching the negative terminal of the jump cables to any part of the chassis, and the positive to the positive terminal of the starter. Had a hard time locating it, you have to reach behind the starter and find the terminal with a rubber cover/insulation.
Good luck!
Old Sep 10, 2008 | 05:22 PM
Yeah, sounds like valet mode is kind of overriding everything...
Old Sep 14, 2008 | 10:40 AM
jag_genius's Avatar
Default RE: XJR trunk woes...
Once open check to see if your trunk lights work if not then the microswitch is toast. Causing the buttons not to work
Old Jan 28, 2010 | 12:19 AM
wilsongsx's Avatar
Default Trunk stuck
In searching the forums, I found this thread. Thanks all! I will try this solution tomorrow.
I believe I have the same problem. Which is:
* The trunk will not open with either: (a) Keyless remote; (b) dash button; nor (c) key
I have not used my valet key in months, so I don't think that is the issue.
The remote seems to be fine. It unlocks the driver door upon 1 push; all passenger doors upon the 2nd push; but no trunk release upon the 3rd push....
Thsi problem literally appeared overnight..
Battery is/has been strong.
Old Jan 28, 2010 | 04:40 AM
Real_Tech's Avatar
Default You do realize...
that this thread teaches people how to break into your Jaguar XJ6 '95-'97 and XJ8 '98-'03.
Personally I would remove it whether it helps or not.
Old Feb 7, 2010 | 11:57 PM
cutlass's Avatar
its no secret, already common knowledge among thieves
Old Jan 28, 2012 | 10:02 PM
gocallahan's Avatar
What does the "8 inch" hook look like to buy at auto store? I have this same problem and need to go through my license plate!
Help!
dsnyder586
Dec 29, 2024 07:39 PM
martybmw
Apr 2, 2016 04:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
prettydaim
Sep 7, 2015 05:16 PM
