ABS Sensor update
Old Feb 20, 2013 | 06:06 PM
sogood's Avatar
Default ABS Sensor update
Just for the benefit of anybody who may have been following my ABS sensor saga, I have clarified things in relation to the different sized sensors. The reason the sensor that I got is too long to fit into its socket is because it is a FRONT sensor! Studying illustrations and part numbers on ebay revealed my error!
So, for the record, the sensors all look the same except that the front are a simple metal, cylindrical body, with a black plastic extension. The rears are short, metal, cylindrical, without the black plastic extension piece.
Official part numbers are; LNA 2220 AB Front, LNA 2221 AB Front
LNA 2222 AB Rear Right (Drivers side on RHD)
LNA 2223 AB Rear Left (Passenger side on RHD)
Apparently, the rears are interchangeable with each other, although the Left sensor also doubles as a wheel speed sensor for other functions.
So, now, all I need ( rather badly) is a right rear drivers side sensor. Some available on ebay etc. but most are crazy money.
Old Feb 21, 2013 | 02:43 AM
theJPster's Avatar
You can't beat Jaguar Classic Parts for illustrations.
Part no. LNA2220AB | Wheel speed sensor Parts From Jaguar Classic Parts UK
Old Feb 21, 2013 | 06:30 PM
sogood's Avatar
See, this is partly how I became dazed and confused. The diagram above, marked by you as part no LNA 2220 AB, shows two sensors, one of which is indeed LNA 2220 AB, that is the front sensor, which you can clearly see has a longer body. The rear sensor, LNA 2222 AB has the shorter body. But the right one is in the post as I type, so, watch this space, again!!
Old Feb 21, 2013 | 07:33 PM
b1mcp's Avatar
As you say above there are 2 different part no.s for Right and Left sensors. But they are not interchangeable. Functionally they are the same but they are handed, so if you swap them around the cable will be pointing the wrong way.
Old Feb 23, 2013 | 06:50 AM
x300man's Avatar
sorry sogood just taken part of and it is plastic and guess what I BROKE IT while doing so, after driving back from ramsgate stupid o"clock this morning so sorry
Old Feb 27, 2013 | 04:22 AM
sogood's Avatar
Belated thanks for you efforts. I have the correct one on the way from ebay, so hopefully, this will be the end of my issues, for now!
Thanks again.
Old Mar 2, 2013 | 06:58 AM
x300man's Avatar
glad you found one and no problem its me that late replying with working away allweek
Old Mar 2, 2013 | 02:33 PM
sogood's Avatar
The sensor arrived on Thursday, put it in on Friday, all sorted and just in time as I had my annual NCT/MOT today, Saturday! And she pased with flying colours, no advisories, no faults! Happy camper!!
Old Mar 8, 2013 | 03:34 AM
x300man's Avatar
glad you are back up and running happy motoring
ericjansen
Dec 19, 2021 12:20 AM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
picard
Oct 12, 2015 11:56 AM
pocketrocket
Sep 3, 2015 07:44 PM
