aerial and cd changer
Old Feb 1, 2009 | 04:36 AM
newquaymarc's Avatar
Default aerial and cd changer
morning guys
got a little prob with the aeriel and cd changer
some days works ok but like this morning, up went aeriel
but get 500 yards down the road and it goes down on its own and i have found the cd unit
does'nt work
stop the car turn off and back on and all ok cd changer works and aeriel goes up
is there a common wire for both units, ie a swithed feed from head unit?
ive checks all earths i can see and all seem ok
cheers
Old Feb 21, 2009 | 12:42 PM
Default aerial n cd
I just unplugged every plug i could find in the boot and sprayed with WD40
and all was cured
Old Feb 23, 2009 | 03:54 AM
cool's Avatar
Use contact cleaner and apply contact fluid, and not WD 40, by the way WD40 is to release stuck or sticky parts and at the same time to lubricate, while a contact cleaner tries to clean the surface of the metal in direct contact with current.
Old Feb 23, 2009 | 01:22 PM
i have to disagree on that one, i have used WD40 for years, i even used it when i worked for IBM and it was far better than contact cleaner, it does what it says on the tin, water displacement, going by the electrics on these cars they are built to the same standard the old mainframes were,, very badly.
Old Feb 27, 2009 | 11:45 AM
cool's Avatar
whether to follow or not is all up to the individual owner. In fact contact fluid (besides contact cleaner) may not be too familiar with most mechanics, but it is a common relief to the electrical contacts problem since most of the car manufacturers find it problematic when it comes to consistency of electrical current running between metal contacts for automotive electrical system after a duration of usage.
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
leep123
Sep 26, 2015 04:53 PM
texaspete
Sep 10, 2015 08:34 AM
