Aftermarket key fob
Old Oct 4, 2024 | 09:44 AM
Advinnie's Avatar
Default Aftermarket key fob
Hi all I have a 1997 3.2. I need a new key fob and as far as I can tell it’s a 433mHz one I need. Now can you use any 433mhz key fob ?
Old Oct 4, 2024 | 10:24 AM
Parker 7's Avatar
Saab around the same year may be an option
There are parts on E - bay to repair your original
There was some mixing around of the rear glass in whole car production and it's already manufactured antenna type , this is a TSB
I have an extra 433 I picked up at a salvage yard , but my system is a 315
Old Dec 8, 2024 | 08:24 AM
macribor21's Avatar
FYI, I have changed the battery on these in the past, and tried to fix the "clicker" mechanism in the fob in the past with limited success. Any ideas? Thanks in advance!
Old Dec 8, 2024 | 10:27 AM
motorcarman's Avatar
Info for you!
File Type: pdf
Old Dec 17, 2024 | 09:03 AM
Alexander Gurney's Avatar
They are often found on e-bay, I recently bought one and then successfully programmed it to my car!
Old Dec 17, 2024 | 05:42 PM
watto700's Avatar
Try a locksmith, several I've been into lately have a FOB replacement service, maybe worth trying. If you have a funtional FOB take it with you.
Cheers,
Jeff.
JaguarXJL15
Jun 21, 2025 02:21 PM
Tracee
Jun 3, 2022 05:59 PM
dougdean
Sep 23, 2021 07:57 AM
Carthage4404
Mar 19, 2013 03:02 PM
