Air con question.
Old Jul 24, 2019 | 12:32 PM
Stu II's Avatar
Default Air con question.
The air conditioning on my car blows cold out of the two passenger side (LHS) vents, but much warmer out of the driver's side vents. Does anyone has any ideas as to why this maybe be happening?
Old Jul 24, 2019 | 12:50 PM
Lady Penelope's Avatar
There is a self test on the control panel in this TSB
http://www.jagrepair.com/images/TSB/...stem%20DTC.pdf
See page 78 for the flow diagram
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
In testing the door motors you can hear them run with a 9 volt battery if you pull the connector off the AC ECU before digging the motor out
You can drive the motors to the desired position and clip the wire to hold it for the season before readjusting in the new season
f
Tink
Sep 1, 2016 01:04 AM
Sparkchaser36
Jun 11, 2012 03:33 PM
ohsigmachi
Mar 16, 2010 01:03 PM
Hong
Jul 13, 2008 11:43 PM
