Alarm Problem?
Old Dec 1, 2013 | 12:59 PM
nassy199's Avatar
Default Alarm Problem?
Hey i Purchased a 96 Jaguar XJR a couple months back without a keyless remote...couple weeks later i started having problems with be able to start. learned from this site to check the battery, change the battery,inertia switch,shifter problems etc. at first i could disconnect the battery in the evening and in the morning before work connect and would fire right up...now nothing i do the same things that worked before and i get nothing i really like this car please someone help me save my pretty kitty....
Old Dec 2, 2013 | 04:35 AM
sogood's Avatar
When you say you have trouble starting, can you be more specific? Does the engine turn over? Does it turn over slowly? Does it not turn over at all? Do you know what your battery voltage read when engine switched off and when engine is running? ( difficult to know now, yes!)
Did you replace with a new battery?Get the battery charged up fully, make sure the terminal connections are clean and tight and check for any earth connections. Check connections at the starter motor. The list is endless but working through things methodically is the way to go and start with the simple stuff. But a good battery is a must. These cars need full power!
I wouldn't think the alarm is the problem if the car was running previously.
Bigvettefreak
Sep 6, 2015 04:27 PM
mcdutch
Sep 4, 2015 03:38 AM
philwarner
Sep 3, 2015 10:14 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
