Alignment issues
Old Dec 2, 2013 | 09:26 AM
etaent's Avatar
Talking Alignment issues
Hi guys, so even after purchasing new tires and having the car computer aligned, it still pulls ever so slightly to the right. What else could it be? Any ideas would be greatly appreciated!
Old Dec 2, 2013 | 09:29 AM
jimbov8's Avatar
Steering/suspension bushing or slight brake binding perhaps.
Not really a lot else it could be.
Old Dec 2, 2013 | 11:13 AM
n_sweeney's Avatar
A very simple thing to test is the tires themselves. Even new tires sometimes cause this. Swap the front tires from side to side.
Old Dec 2, 2013 | 12:15 PM
Doug's Avatar
Yup, could be any of the above.
Or....maybe the alignment needs a bit of a tweak. If so, it wouldn't be the first time a car was aligned and needed a follow-up visit. Sad but true is that many alignment techs assume that if they set everything "within spec" that a post-adjustment road test, and further adjustments, won't be required.
Old Dec 2, 2013 | 01:49 PM
etaent's Avatar
Thanks guys! I did take it back to double check, but in all honesty I know I need new springs for the front because they curve out and hit the shocks when I turn the wheel all the way, Im sure I need new bushings as well. Does anyone have a list of all the bushings so that I could buy them and do them all new when I install the new springs?
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
James007
Oct 3, 2015 03:29 PM
Darrenmb
Sep 8, 2015 06:12 PM
James007
Sep 6, 2015 06:47 PM
