ambient temprature sensor issue
Old Jan 16, 2022 | 07:30 PM
Spud Maat's Avatar
Default ambient temprature sensor issue
So, i had error code 12 on my climate control, whet to investigate and realised that not just the sensor was missing but the entire brake duct.
so i purchased a second hand unit, finally got around to installing it,
cleared the codes on the AC,
but damn, no reading from the sensor “- -“ is all i get.
the error code has gone so the sensor has continuity and is completing the circuit, if i unplug it the code comes back,
But the sensor is not working.
now before i buy a new one, is there anything i am missing? Anything i can try?
and if i need a new sensor, does anyone actually know anywhere that has new ones? Preferably Aussie, but will buy from overseas when i need to.
Old Jan 16, 2022 | 09:29 PM
Parker 7's Avatar
The sensor is a thermistor ( semiconductor ) that needs power from the testing meter to the device to read correctly , this is different then a thermocouple that is reading resistance through the device
This means you can't use a pocket 1.5 volt test meter
The calibration chart is on page 100
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
Old Jan 16, 2022 | 09:42 PM
Spud Maat's Avatar
so how exactly would i test it?
like i said atm all i know is the circuit has power as it lights my little led test light, and the sensor completes the vanishes as my error code vanishes.
Old Jan 16, 2022 | 10:24 PM
Parker 7's Avatar
Since the chart is for return voltage to the climate control ECU ( your meter in reading voltage does not supply power to test the device ) you would use a different method
You can nick the insulation on the X color wire as the connector is connected
You would have to use a very good ground stud
Do you have a noise suppressor ( long cylinder under the car by the alternator) not installed in the same area as you may be hooked up to a spare connector ?
The noise suppressor is hooked up to the alternator with a connector in between and all X300s came with them
Old Jan 16, 2022 | 10:48 PM
Spud Maat's Avatar
no idea about the noise suppressor i will look.
but i must be connected to the right plug as it comes from the correct connectors, with the correct colour wiring, and connecting to it removes my climate control error code.
as far as testing hoes, interesting as i noticed there was a nick on the insulation on the wire and i thought “thats odd” but of the wire a has been nicked it would stand to reason that the wreckers tested it. And if they tested it i assume it worked before they sold it.
probs gunna be the weekend before i can get back under the car.
Old Jan 16, 2022 | 11:07 PM
Parker 7's Avatar
The nick has to be resealed as is very prone to corrosion under there
It may already be compromised and miss leading as calibrated correct reading to the climate control ECU
The nick most likely came from the previous owner that had issues so that would make the sensor suspect
valid connector hooked up makes sense
Old Jan 16, 2022 | 11:09 PM
Spud Maat's Avatar
The nick has to be resealed as very prone to corrosion under there
yeah i always reinsulate everything.
if the sensor is busted finding a new one is probably a PITA and buying 2nd hand is always a crab shoot.
Old Jan 16, 2022 | 11:21 PM
Parker 7's Avatar
There has to be a good Jaguar salvage yard in Sydney
The sensor is probably the same part # on the later V8 version of the X300 being the X308 ( 1998 - 2003 )
As they are identical Denso systems
Old Jan 16, 2022 | 11:26 PM
Spud Maat's Avatar
i have yet to find anywhere of good help. There are two places i have found that are jag specialists that have not had any of the parts i have previously asked for, and even interstate i have had some issues. Seems that when spares do come up they seem to go quick, i dunno, i have asked in the regional thread but got no helpful responses so i dunno keep trying and maybe one day i will find.
btw, seeing as how helpful you are, did you see my thread regarding gear shift interlock. Lol…
Old Jan 16, 2022 | 11:39 PM
Parker 7's Avatar
Not yet as I am doing Kidney Dialysis at home
Little Bubba and Little Boe Boe passed away
Old Jan 16, 2022 | 11:43 PM
Spud Maat's Avatar
Sorry to hear. Take care.
Old Jan 17, 2022 | 12:10 AM
Spud Maat's Avatar
Scratch all that….. it just started working……
seems it just needed to go for a nice drive and drive itself in….
ferrral
Aug 13, 2021 04:11 PM
mick99
Feb 1, 2016 10:51 AM
kelv1962
Feb 22, 2012 10:22 AM
carlorner
Aug 29, 2011 12:17 PM
Jag4.0
Jul 14, 2008 03:38 PM
