Another Seat Module Question
So I have never gotten the memory to work right, but I have new symptoms that might help diagnose by you experts. Here is where I stand
1. Put in the key the column goes to the right location
2. The mirrors go to the correct location
3. The seat does not do anything. However, when I pull the key out, the seat moves all the way back
I now have the Autel MaxAP200, and it shows no current error codes. There were some old ones, but I think those were from when I changed the seat module for the third time. Does this sound familiar? Does anyone else have the same issue?
I went through the TSB, and it is telling me
CheckPoints: 1 A chaffed or damaged harness.
2 Loose or backed out pins to modules and the corresponding harnesses connectors.
3 Poor connections to motors or potentiometers.
4 Potentiometers not functioning correctly – use a data logger to check the output of the potentiometers.
5 Potentiometer may be out of range – this may happen if a memory position is towards the maximum travel of an axis.
6 Poor connections to switch-packs.
7 Short or open circuits on harnesses.
8 Physical damage or wear of mechanical components such as slides, linkages, or gears.
I can move everything to where ever I want, so not sure this fits me. It is only the memory recall for the seat.
I have posted the TSBs many times and GUS has them on his website. (I sent them to him)
I replaced MANY seat position feedback potentiometers when these cars were in 'new-car' warranty.
I only replaced them in ONE car out of warranty. There are 5 seat position sensors. The estimate was $1900.00 'customer-pay' and most of the time DECLINED.
The sensors are $300.00 EACH. The labor was a few hours (3 hours I think) to remove the seat and replace/adjust all the potentiometers.
The Jaguar warranty time is a joke if you ever tried to do the job in the time allotted.
There is a trouble-shooting tree in the TSB 15-50.
I will bet that one of the feedback pots has gone '****-up' and needs replacement.
Most people just turn the switch on the column to OFF and go on with their lives.
good luck.
good luck.
Yea as you can see in my posting I went through that tree but the outcome of the tree is up in the air. Everything is working fine but the memory of the seats. I will have to see if I can find another module and see if that makes a difference. At least I have the steering column and the mirrors and the seat moves back for exit
o2manyfish
Sep 3, 2014 04:20 PM
