Electric Seat Fault
Old Sep 21, 2010 | 09:44 AM
ChrisXJR's Avatar
Default Electric Seat Fault
Hi, i have a 1998 XJR.
The drivers electric seat will move if the use the memory function in the door panel, but the switches on the seat wont move it, i have replaced the seat switch to no avail, it would be ok if any of the memory settings were mine but they are not they belong to the 8 foot tall previous owner haha, so please help if you can?
Regards,
Chris
Old Sep 21, 2010 | 03:07 PM
Sean B's Avatar
If you've swopped the switchpack and still no joy, it could be wiring to the module under the seat. You'd have to unbolt the seat and check the wires going from the switchpack to the module.
Old Sep 23, 2010 | 12:07 PM
ChrisXJR's Avatar
No joy, everything looks in place and in good condition, next i think i will try a new (second hand) seat modual.......
Old Sep 23, 2010 | 02:27 PM
Sean B's Avatar
you can check if it's the module by using your passenger one (if that's behaving correctly) just swap it for the drivers and see if you get the seat to work. Then its a case of ringing around the Jag breakers like Eurojag etc for the same year module, you'll have to get it programmed to the car, that's a trip to a main agents and the use of the IDS software....
Old Sep 24, 2010 | 01:11 PM
ChrisXJR's Avatar
Sean, thanks for your help, iv fixed it, theres a 5 amp fuse in the rear heal board fuse box No8 that feeds the seat swich and the stearing wheel movement switch, i was just looking through the service book at the fuse locations and found out the switch is fused.....ALL SORTED YAY
Thanks again!!!
dsnyder586
Dec 29, 2024 07:39 PM
Clamdigger
Sep 12, 2015 03:43 PM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
