Anti Lock - intermittent
Old Jun 14, 2012 | 02:34 AM
AlbBolivar's Avatar
Default Anti Lock - intermittent
Sometimes, whenever I drive about 50 ft or so, my anti lock light comes on and doesn't go away until I turn the car off and then start it back up and it's gone.
Sometimes it won't come back after driving and for the past 2 days the light hasn't come on. I inspected the front sensors and it looks like there is a ground wire on the driver front that is no longer connected.
Would that ground wire be the problem? I've tried looking online for replacement sensor cables but none of them seem to have the ground wire connect so it makes me wonder.
Old Jun 14, 2012 | 07:25 AM
Doug's Avatar
Seems plausible that it could be the problem, yes. Repair the wire and see what happens.
Old Jun 14, 2012 | 09:23 AM
AlbBolivar's Avatar
Thanks Doug. I'll see what I can do about repairing it. The wire actually broke off at the rubber boot so it'll be a little tough getting it back together.
Old Jun 17, 2012 | 04:58 PM
JonnyO's Avatar
Mine has been doing the same thing. I took it to my Jag mechanic and had the codes pulled.
I believe the code was C1095. I think he said the ABS control module is failing.
Old Jun 17, 2012 | 11:16 PM
aholbro1's Avatar
Here you go, Johnny O:
https://www.jaguarforums.com/forum/x...c-fault-44272/
Old Jun 19, 2012 | 08:12 PM
jagdayn's Avatar
Somebody cut both the ground wires on my xjr prior to me owning it and I am looking to fix this. Interested to see how this repair goes for you. Good luck.
Dayn.
Old Jun 19, 2012 | 10:27 PM
AlbBolivar's Avatar
It's weird, since I took off the wheels and found the cut ground wire I haven't gotten the anti lock light.
If it does come back, what I am going to do is cut about an inch of the rubber boot off and see if that's enough to connect both ends back together.
Either way, I will let you know how it goes.
jluckcuck
Nov 6, 2015 07:49 AM
millertic
Sep 30, 2015 08:11 PM
Listers
Sep 30, 2015 07:45 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
