bearing issue in dif?
Old May 3, 2013 | 06:44 AM
Gareth Reaper Pollard's Avatar
Default bearing issue in dif?
Good afternoon all.
I have just replaced the rear hub bearings on my 96 3.2 sport and noticed that there is a lot of play on the half shaft at the diff end. as in i can move the hub and shaft about 1 inch. now all the halfshaft assembly seems fine with no play issues in the uj's. I assume its a bearing in the diff.
Any ideas on this?
Thank you
Old May 3, 2013 | 08:23 AM
RJ237's Avatar
If you mean you can rotate 1 inch, that's backlash in the gears. I don't know if that's normal, but there is always some play.
Old May 4, 2013 | 03:40 AM
Sorry. should have said i can pull the hub and shaft 1 inch away from the diff.
PMKimpton
Aug 3, 2019 08:22 PM
kstevusa
Sep 7, 2015 01:12 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
