Blue Smoke & Engine Vibration
Old Aug 3, 2009 | 08:21 PM
JagtechOhio's Avatar
" Gaskets and grummets [sic]" is a little vague. There are composite paper gaskets that go under each coil, if there was $20.00 on the ticket for these that is a normal add-on, does not require additional labor, and fixes absolutely nothing.
If he replaced the cam cover gasket and the six spark plug well seals that are an imperative addition to this repair, he was trying to stop the oil leaks which are the reason that the spark plus wells are full of oil, and why the engine was leaking externally. Either he didn't do this work, didn't do it properly, or was trying to seal up a cam cover which has deteriorated to the point that it must be replaced for the gasket and spark plug well seals to get the job done. It happens with the '95 to '97 cam covers (valve cover).
None of this is very complex.
Old Aug 3, 2009 | 09:51 PM
poboyblues's Avatar
In addition to Andy's spectacular post, I might add that the audience would like to know why the check engine light is on.....Have ya scanned the ECM to read the codes? I am just grinding my teeth wondering why.
And why didn't your boy tell you why the light was on and give you the code/s?
Old Aug 3, 2009 | 09:53 PM
You kiss ***, now I suppose I have to back you up? ;}
Old Aug 3, 2009 | 10:28 PM
cooke's Avatar
If you've got fresh oil on the plugs you need to do a compresion check on all cylinders you might have cracked piston ring or bent valve, the compression check will tell you for sure where the problem is.
Old Aug 3, 2009 | 11:26 PM
poboyblues's Avatar
Talking
LOL. Thought you'd like that.
And yes, you have to back me up.
Old Aug 3, 2009 | 11:27 PM
To Cooke:
Please don't freak the poor guy out, the oil is on the the top side of the plugs, not on the electrodes.
Bent valves will not oil-foul a spark plug.
Wolfy
May 28, 2024 08:06 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
cissdm
May 3, 2016 06:02 AM
bdboyle
Sep 4, 2015 06:16 AM
