Boot lid electrics not working
Old Feb 20, 2012 | 03:05 PM
Derek's Avatar
Default Boot lid electrics not working
Ok...heres one someone most have experience of. My x300 has no electrics on anything attatched to the boot lid....ie; boot release (fob, dash, or cat buton), boot (trunk?) lights, or plate lights. I figure an earth problem, or the flexi wire . I put a meter on a few things, an I get no live , OR earth (-)...any ideas will be appreciated
Old Feb 20, 2012 | 06:25 PM
aholbro1's Avatar
check the wiring loom at the boot hinge. A common place for chaffing and if I recall those are the symptoms. Try a couple of searches; "boot" and "trunk" here in the x300 section should catch them all.
Old Feb 26, 2012 | 04:13 PM
Derek's Avatar
Well....you were bang on...when i took the tape off the loom, there was only 1 wire intact ! Soldering iron, heatshrink, sorted...so thanks for the advice.
Old Feb 26, 2012 | 06:42 PM
aholbro1's Avatar
Glad to hear you got it sorted. Mine has never caused a problem but lots of posts here about that being a common failure.
Old May 28, 2012 | 02:58 AM
RussellCox's Avatar
how do i get into the boot to repair the wiring loom please.key fob inactive.
Old May 28, 2012 | 06:47 AM
sparkenzap's Avatar
Russell:
The key is supposed to work in the hole in the badge. Some of them apparently gum up. I would try some lubricant like wd-40 in that lock hole before I resorted to pushing the lock rod to the side through the top license tag screw hole. I would normally prefer some dry lubricant, but once the thing is already stuck, I believe WD-40 is about all that might work. And, it is not a normal tumbler lock.
Old May 28, 2012 | 09:30 AM
Derek's Avatar
Keep trying the key...its going to be difficult without it!
Forcedair1
Sep 8, 2025 01:57 PM
XJsc-guy
Nov 23, 2015 01:56 PM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
