brake pedal switch problem solved
Old Feb 28, 2013 | 10:13 AM
Chris Green's Avatar
Default brake pedal switch problem solved
hi guys
had to share, i had a problem/s with my car, new battery (as advised) solved most but one. my brake lights were not working also it would not come out of park? so i decided to check switch, not easy to get to but had it out and it worked fine, then i noticed one part fit's in other and adjusts so i moved them apart as far as possible and re-fitted and now car comes out of park and brake lights work
added photo
Old Mar 1, 2013 | 04:21 AM
SleekJag12's Avatar
Nice fix, Chris. The "no cost" fixes are the most rewarding! Although I had to buy a switch for my six a few years back. All has been well with that since (had the same symptoms). Done a bunch of no cost fixes on my newest addition VDP in the past few months. It had many little problems that I was able to sort out. Cheers!
Old May 3, 2013 | 09:27 PM
Sauntache's Avatar
Originally Posted by Chris Green
...So i decided to check switch, not easy to get to...
Could you give a quick run-down of the steps required to access it?
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
