Bulb Failure Warning Light
Old Mar 19, 2019 | 05:27 AM
Shinda’s XJR's Avatar
Default Bulb Failure Warning Light
Hi there,
I have a small issue with my 95’ XJR. It is showing a bulb failure warning light on the dashboard, so I checked around the car and could not find a single bulb out. After a drive last night I found that under braking, the warning light goes out and then comes back on when I take my foot off the brake.
Does anyone have any ideas about how to go about this issue or what it could be.
Thanks in advance!
Old Mar 19, 2019 | 05:53 AM
AJ16er's Avatar
I would inspect both brake light bulbs.
Old Mar 19, 2019 | 06:04 AM
Originally Posted by Shinda’s XJR
I have a small issue with my 95’ XJR. ....
Welcome to the forum Shinda’s XJR,
I recall both my XJ40 and X300 were sensitive to cheap replacement bulbs.
Old Mar 19, 2019 | 09:39 AM
Steve M's Avatar
My warning light comes on intermittently; it is probably just a case of removing bulbs and cleaning the contacts.
I'll get round to it one day.
Old Mar 19, 2019 | 10:21 AM
Originally Posted by Steve M
..... I'll get round to it one day.
Here you are:
Old Mar 19, 2019 | 10:37 AM
Steve M's Avatar
Thanks, that's just what I need!
How do I make it fix my lights?
Can you supply by the hundred as I have a **** pile of stuff to do?
Old Mar 26, 2019 | 06:06 AM
Thanks for the advice and the kind welcome. I will introduce myself on the new member area now!
I spoke to a local headlight fitter and he said that the issue is electrical and recommended I replace the whole tail light unit.
Old Mar 26, 2019 | 09:59 AM
Steve M's Avatar
Well, it's definitely electrical so he's not wrong there.
As he is a headlight fitter (is that a job?) he is bound to go for the most expensive option.
It could also be the warning light relay (I assume that it has one).
Have you pulled the bulbs and cleaned the contacts?
Don't forget the rear number plate lights.
Old Mar 26, 2019 | 11:00 AM
Lady Penelope's Avatar
In the under corners of the car there are 4 black connectors that get corroded
corrosion limits the current flow and that's what the bulb warning is looking at
The connector part # EC13MK is the same as the Papa Indy 1 and 61 in the engine compartment just behind the washer fill cap
The bulb contact tabs can be pulled out slightly
Old Mar 27, 2019 | 06:18 PM
Lol maybe fitter was a bad choice of words. He owns a vehicle modification shop and specialises in lighting. You've hit the nail on the head with the number plate light as one of those is out. Much appreciated! The cowboy told me a number plate light wouldn't trigger a warning on the dash. Will be paying him a visit on Friday with some choice words! Thanks again!
Old Mar 28, 2019 | 10:18 AM
So after finding out that the number plate light was out, I went to buy a new set of bulbs. When I went to fit them, I found out that the housing that the bulb fits into has rusted over time and needs replacing. At least I don’t need to replace the whole tail light like that cowboy advised! Thanks for all the advice guys. Much appreciated!
Old Mar 30, 2019 | 02:47 PM
OX300's Avatar
Hello all,
My connectors has a couple of wires cut. Any suggestion why that might be?
//Olle
Old Mar 30, 2019 | 02:51 PM
Steve M's Avatar
Try and be a bit more specific!
What connectors?
If it is a different problem then start a new thread.
What car is it?
Old Mar 31, 2019 | 12:19 AM
OX300's Avatar
Oh sorry- the black and White connectors that Lady Penelope is mentioning. Mine is an X300 -95.
I will take a Picture later to show you!
Olle
Old Mar 31, 2019 | 03:50 AM
Steve M's Avatar
Ok!
Old Mar 31, 2019 | 04:20 AM
Those 2 connectors are very important as they contain some engine regulation wires
  • In a pinch the effected wires can be simply spliced to get you going and a connector can be ordered later
  • I have a wiring color code chart for both the connectors on my laptop somewhere to piece it together
  • The V12 has 2 extra wires in the same connector but the 2 wires only come into one side of the connector like I found on mine for the inline 6, this may be your issue
Old Mar 31, 2019 | 10:50 AM
OX300's Avatar
Ok, so I managed to a couple of blurry pics of my connectors.
What I thought was cut leads was actually plugged holes (it seams), so never mind that!
But- to get rid of the bulb failure warning:
Mine comes on when I put on the parking- and main beam and my right turn indicator flashes in double speed. I tried changing bulbs and a "hard reset" but it´s still there.
Do you Think I should replace the connectors you Point at on the Pictures? Maybe just some Electronic cleaner spray....?
Thanks for helping out!
/Olle
Old Mar 31, 2019 | 10:52 AM
OX300's Avatar
Old Mar 31, 2019 | 12:05 PM
The double speed turn or direction flashing indicates a low current detected in the external lights control modual
On the 95 up to a certain production number there are 2 in the front , later they just have the one only in the trunk
You may have a wrong bulb in a socket not allowing enough current to flow , a bad socket , the contact ears on the bulb itself can be sprung out a little , or one of the connectors in the 4 under corners of the car can be corroded
See page 111 for above VIN 739427
page 101 for below VIN 739427
http://www.jagrepair.com/images/Auto.../jagxj1995.pdf
The repeaters behind the front wheels should also be flashing , you can remove the socket by pushing the socket fwd or backwards on then pushing or puling on the front or aft edge . The wires going into the EV - 1 type connector can be broken and can be swapped with the ones on the trunk dome lights
See page 115 for a 96 as its a clearer diagram then the 95
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
Notice the grounds for the bulb current to pass through are the BL1 - ( left ) and BR1 - ( right ) connectors under the car like and the same part # as the Papa Indy 1 and 61 you were looking at behind the washer fill cap
There have been problems noted in a wire disconnected on the turn signal switch that can easily resolderd back on , you will notice this if you get no turn lights on one or both directions
editing
Old Mar 31, 2019 | 01:08 PM
OX300's Avatar
Thank you very much for these thorough instructions. You´re a jag-wizard!
/Olle
