Bulb out! All are fine and working?
Old Sep 5, 2013 | 03:40 PM
Chris Craddock's Avatar
Default Bulb out! All are fine and working?
I have a light on the dash that says my buld is out
but I replaced the only one that was out and the light on the dash is still on
the fog lights do not turn on
Could that be the problem?
Old Sep 5, 2013 | 05:56 PM
aholbro1's Avatar
If it is one of the fogs, the dash warning will only illuminate when you turn them on. if on all the time, it is a bulb that burns all the time. If you have a brake light burn out, you'll notice the dash caution light only illuminates when you hit the brakes, etc.
Old Sep 6, 2013 | 09:30 AM
So if its on all the time I wonder what it is Im gonna do another inspection of all the bulbs
Its sooo annoying.
Thanks for the tips :-)
Old Sep 6, 2013 | 04:20 PM
Adrianl's Avatar
Check the license plate lights. They're really easy to overlook.
Old Sep 9, 2013 | 07:04 PM
Sadly its not the licence plate
just checked
Old Sep 9, 2013 | 07:12 PM
sparkenzap's Avatar
When you say "all the time", you mean even when the running lights are off?
Old Sep 9, 2013 | 07:30 PM
aholbro1's Avatar
When I said "all the time" I probably didn't mean it! What I meant is the dash warning won't bother you about a burned-out bulb you aren't trying to use. So his mystery failed bulb would be one that is supposed to be on when he has the warning light.
Old Sep 10, 2013 | 01:52 AM
sparkenzap's Avatar
bro-
Your answer was clear and significant!. I was asking Chris if he has fault indication "all the time".
Old Sep 10, 2013 | 07:57 AM
Yup its always on. My dash looks like a christmas tree there are so many lights
Old Sep 10, 2013 | 09:56 AM
sparkenzap's Avatar
Ohhh... So that means you have a "bulb failure" all the time and other (seemingly nuisance) warning lights too? maybe you have a instrument cluster failure?
Old Sep 10, 2013 | 12:03 PM
Jagboi64's Avatar
I'm not sure how the X300 works, but on older Jags it sensed the current draw from side to side and if there was an imbalance, it put the bulb fail on. I'm thinking that if your replacement bulb is not the same wattage as what is existing ( easy to do, as the European bulbs and US parts store bulbs can vary slightly) then the lights will be on, but the bulb fail will still be lit.
Try replacing the bulbs in pairs, or make sure the replacement is exactly the same as what it should be.
Which bulb did you replace, and what market is your car? I ask about the market, as Canadian cars with DRL's turn everything on, not just headlights. If the socket on a rear side marker is corroded (commonly happens) the current draw won't be what it should be and can turn on the bulb fail.
Old Sep 10, 2013 | 12:46 PM
Thanks Guys! Im gonna go to the store and just buy a few packs to investigate cheers! ;-)
Old Sep 11, 2013 | 05:50 AM
Bought virtually every light for the car last night hopefully Ill have time today to swap em!
Old Sep 19, 2013 | 11:18 PM
Ah I think its the two rear brake lights on the sides of the car need to replace the housings of each bulb on both sides... :-(
also fog lights are not working and I replaced the bulbs in them
Old Sep 26, 2013 | 05:45 PM
sharay38's Avatar
I missed this thread previously. As as note, my '91 XJ40 had bulb out indication I had trouble locating until my son noticed the reverse light on the left side wasn't lit as I backed out of the garage. Changing that bulb cured the bulb out indication. Not sure if it would be the same for the X300.
toronadomike
Jan 22, 2026 10:13 PM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
XFR_Gold
Sep 2, 2015 12:24 PM
XJsc-guy
Sep 2, 2015 11:43 AM
