A/C backlight and radio antenna questions
Old Jan 12, 2012 | 07:33 PM
TopHatChef's Avatar
Default A/C backlight and radio antenna questions
Okay, two little q's:
The backlight on the A/C temperature screen went out, how do I replace it? Can I?
My radio antenna recently stopped going up and down. I think it's just the antenna by the sounds of it when it was breaking (sounded like the plastic bit inside broke), but I don't hear the motor. Where's the best place to buy a replacement?
Old Jan 12, 2012 | 10:10 PM
Doug's Avatar
If you remove the radio/climate control/clock stack you'll see that the climate control head has a plastic cover on the back. Remove the cover and you'll see the replaceable twist-lock bulbs.
Replacement bulbs are tricky. I bought umpteen different ones on-line for $1 each but none matched the color/instensity of true Jaguar bulbs....which are "stupid expensive" at $6-$7 each.
The antenna's nylon drive cable probably broke. I got a replacement on Ebay as I recall...less than $20 I think. It comeas as a mast-cable assembly. Sometimes the new cable can simply be fed into the motor, letting the take-up wheel pull the new cable in.
In my case there were broken bits inside...so I had to open up the motor. No big deal.
Old Jan 14, 2012 | 11:46 AM
TopHatChef's Avatar
Thanks loads Doug. I knew you'd know what I'd need to do. I'll probably just go get the bulbs at the dealer. I recently moved, and the local dealer is right next to a mall I like and haven't gotten a chance to visit them. If I'm going to go through the PITA motions of removing the climate control, I'm only going to do it once.
Old Jan 14, 2012 | 11:56 AM
TopHatChef's Avatar
I just went on eBay looking for the antenna. Can anyone recommend a good seller to look for? I can't remember the guy I've used before for Jag parts, and can't seem to find it in my history because it's been so long since something's gone wrong.
Old Jan 14, 2012 | 12:40 PM
Doug's Avatar
This is the same antenna and supplier I used
URO Power Antenna Mast for Jaguar LNA4134AA | eBay
Looks like the price went up a bit....or perhaps I wasn't remembering correctly
Old Jan 15, 2012 | 05:12 PM
gbmtkj's Avatar
I recently bought and installed this one on ebay:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
It claims to be stainless instead of aluminum, which it implies some others are (?).
$14.95 + $5 shipping.
It arrived quickly, and installed easily. Came with removal and installation instructions, although I also had some from the forum.
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Saturbo
Sep 8, 2015 07:35 PM
TexasCat
Sep 8, 2015 04:36 AM
