Can the waterpump become intermittent?
Old Nov 8, 2015 | 09:19 AM
JTsmks's Avatar
Originally Posted by dagny747
The majority of the cost is the steering rack, what should i pay and where would you suggest getting one? The shop is good and he is willing to work with me. He will use whatever parts I source?
I've been running a refurbished one on my XJS for 6 years now. New X300 $1600 ( highway robbery) refurb approx $300. Rock Auto Has an AC Delco reman unit with lifetime warranty for $322 plus $150 core. I've had zero problems with service from RA.
Old Nov 9, 2015 | 01:02 PM
dagny747's Avatar
First thanks for the suggestion on RA for the steering rack. I do use them and Coventry and SNG. I wasn't sure about a rebuilt for this particular part. It appears the quality of the delco rebuild is better than the others from the description. While I am doing this are there bushings I should also be replacing, I would like to put in poly as much as possible
Old Nov 9, 2015 | 09:00 PM
JTsmks's Avatar
Not a big fan of poly anything on these cars. Poly can be harsh and squeak, the Jaguar ride is very refined and is a result of many years of engineering and the sum of all the proper parts working in unison. I stick with stock on these cars when it comes to suspension components. All IMHO
Old Sep 3, 2020 | 10:31 PM
alexandreraimundo's Avatar
Originally Posted by cool
Water Pump internal component/parts
Hi There Cool!
Would you be able to describe how did you manage to turn the pump apart?
Having some troubles on getting the rotor and bearings out here...
Tks!
Old Sep 4, 2020 | 10:00 AM
littlelic69's Avatar
Originally Posted by alexandreraimundo
Hi There Cool!
Tks!
I’m having the same problem!
Old Sep 10, 2020 | 03:46 PM
Default How to turn water pumps apart?
Hi There Cool!
Tks!
Hi there Cool! Hope everytihing is ok with you...
Can you help us out here with some info about water pumps?
Where did you find your spare parts for it and How were you abble to take it apart? By using pressure?
Tks again for the help!
This Hole is supposed to be here???
Is this normal?
How can I take this apart? Pressure out?
Ferdie
Nov 26, 2018 05:42 AM
Moghut
Oct 1, 2015 01:55 AM
Listers
Sep 30, 2015 07:45 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
