Car monitor issues
Old Dec 16, 2013 | 10:04 AM
etaent's Avatar
Exclamation Car monitor issues
SO my scanner shows that there are 5 monitors not turning on, on my 1996 xj6. I was told to drive it for some time to get them to turn on so I drove to boston and back from NYC all in the same day. That's 220 miles each way and I was doing anywhere from 70-90 mph! Any ideas as to why they aren't turning on? Am I missing something?
Old Dec 16, 2013 | 02:21 PM
AllanG's Avatar
Will need more info.
What type of scanner?
Which monitors?
Have you set up a readiness standard? which one?
Old Jan 6, 2014 | 05:58 PM
etaent's Avatar
Type of scanner is an autotel maxiscan ms309
The monitors that are not coming on are:
-catalyst monitor
-evap system Monitor
-sec air system
-egr system monitor
-oxygen sens monitor
Any ideas?
Old Jan 6, 2014 | 06:39 PM
AllanG's Avatar
Not sure about that particular scanner. Some do require setting up a readiness standard or turning on non-continuous monitors. Have you checked your Autel manual?
My 95 XJ6 is quite finicky when it comes to scan tools, it likes some but not others
Old Jan 6, 2014 | 08:13 PM
etaent's Avatar
Haven't checked the autotel manual but I will tonight when I get home. Didn't even think about that. Thanks!
Old Jan 6, 2014 | 11:53 PM
etaent's Avatar
Ok I checked the manual. It says that the monitors I described are secondary monitors which only come on during certain driving conditions. I have driven to jersey and back, and then continuously drove in the city and still haven't gotten them to turn on. Any ideas? Any specific drive cycle I have to do?
Old Jan 7, 2014 | 06:20 AM
AllanG's Avatar
Yes, as I mentioned they are non-continuous monitors. I peaked at an Autel manual online and it describes the need for a variety of different driving requirements, including stop and go city, highway etc and it also says "at least one overnight off period" Not very specific but maybe you need to do that cycle before trying to read the monitors?. The manual was not for your particular model but generally a manufacturer will use consistent logic in their devices.
Old Jan 7, 2014 | 11:31 AM
etaent's Avatar
Thanks for the info and yes I did exactly as the manual asked and performed a drive cycle with a variety of highway, stop and go city driving, and an overnight off period and still nothing. Any ideas?
Old Jan 7, 2014 | 12:55 PM
AllanG's Avatar
Sorry not really, other than I know in my 95, the OBDII compatibility is a bit spotty. I have 2 scan tools, one works fine,the other not so much
Perhaps Autel could tell you if their unit is compatible with your Jag or if you need any firmware upgrade? It's an outside shot.
Old Jan 7, 2014 | 05:08 PM
etaent's Avatar
So I checked with another scanner and it also says the same 5 monitors aren't ready. Any ideas what could cause this?
Old Jan 7, 2014 | 06:04 PM
b1mcp's Avatar
Don't forget that you are dealing with a relatively old car. I don't know what the rules were in US but in UK cars did not need to be OBD compliant until 2001 (I think) so to have any capability on a 95/96 car is a real bonus.
The monitors you are referring to may simply not be present in the X300 or may not be fully compliant.
Old Jan 7, 2014 | 07:04 PM
AllanG's Avatar
In the US it was a legal requirement for all cars sold from 1996 on to be OBDII compliant. Jag introduced it on the X300 at launch in 1995 but it still had a few kinks
The monitors the OP is looking for are present on X300.
Old Jan 7, 2014 | 08:12 PM
etaent's Avatar
I agree, from what I've read, all 96 and up cars sold in the us must be obdII compliant. Furthermore, I won't pass Nys inspection with 5 monitors not ready. What else can I do?
Old Jan 7, 2014 | 08:21 PM
AllanG's Avatar
Well the only thing I can think of apart from compatibility is the possibility that something is actually keeping the car from getting to that stage.
Do you have any codes showing? Is the car going into closed loop?
I know having a kooky oxygen sensor can effect some of the monitors but I wouldn't have thought it would affect the evap system?
Old Jan 8, 2014 | 09:27 PM
etaent's Avatar
So today I have it another scan and the oxygen sensor monitors and the secondary air monitor are now ready. But the catalyst system and evap system monitors are still incomplete as is the egr system monitor. Any ideas? The egr is not more than two years old.
Old Jan 8, 2014 | 11:27 PM
vandenplas408's Avatar
so i have a very very cheap scan tool for got the name
got it from autozone
i have a 96 x300
and i get the cat codes . i need 4 new cats and the mufflers and i live in cali so mega BUCKS for that.
my coils went out on 3,4,5,6 and it told me those codes as well
i erase them after i fix em
great tool to have
what codes did urs pull?
are you driving with the tool plugged in?
Old Jan 9, 2014 | 06:10 AM
AllanG's Avatar
Well that's progress All I can think of is that the manual said "at least" one overnight off period. So I'm wondering if you continue to run the tests for another day or two and then run do the drive cycle, perhaps all the monitors will come alive?
I don't believe the OP's problem is reading codes, rather that the monitor tests will not run and complete.
Old Jan 9, 2014 | 03:45 PM
etaent's Avatar
I am going to give it a try, and yes I tried looking at it with the car driving and no change.
Old Jan 15, 2014 | 11:52 AM
etaent's Avatar
Ok so I've tried everyrhing. From city and highway driving, to overnight period off and still nothing. Any other ideas?
Old Jan 15, 2014 | 04:49 PM
sparkenzap's Avatar
I would say you have not finished the tests because there is a problem. I assume you are not getting a fault code?
In my case, I could not complete due to a faulty TPS, then the need to calibrate the replacement TPS with the dealer software.
How are the STFT and LTFT and how many lambda cycles do you get per 10 seconds?
I assume "woodhaven" is the one in the US, so does the lambda response for the post cat sensors track the pre-cats, with the post cats somewhat less responsive? (Cat efficiency test)
Is there any chance your gas cap is leaking? And you have not gotten any evap codes?
The evap test can apparently be sensitive to the fuel tank level. As I recall, 3/4 full is supposed to be best.
BTW, steady 35 to 45 mph with slow accel and decel between those, along with several minutes of idle seem to get the test complete in about 35 to 40 miles of driving for me. I think I have read a drive cycle procedure for the X300, but I cannot find it right now.
Good luck
