Cat Back Magna Flow
Old May 26, 2025 | 04:08 PM
thelegend0210's Avatar
Default Cat Back Magna Flow
Hey everyone, considering buying a 96 XJR6. It's not local so I can't go see it in person. The one I'm looking at has a cat back magna flow on it. The guy sent me a video and it sounds nice, though kinda loud. Just wondering if anyone has experience with the catback magna flow on these cars? My worry is drone at high speeds I guess.
Old May 26, 2025 | 06:16 PM
Parker 7's Avatar
I don't have the supercharged or the cats back Megna Flow but I did hear inclings of drone being too much for comfort
This is a video of the other Quicksilve exhaust brand offering as this is the inline 6 ( AJ16 normaly asperated same as the AJ16SC on the 96 XJR6 ) but with a timing sensor biasing bracket ( Andy Bracket )
Your exhaust valves will be timed / angled different than the normally asperated so may not be a accurate comparison but a turn on
Remember the supercharged does not have an exduser in the exhaust line
video coming as computer slow
Old May 26, 2025 | 06:46 PM
Parker 7's Avatar
Inspect the engine ECU connectors on the ECU side for corrosion on the pins ( and inside ECU if allowed ) , ECU located always on the cars cabin side far right in front of the right front door hinge under a small panel
This pic for a British right hand steering model and remove the ECU to see down in connector , there is a external case ground wire that must be installed on the bottom mount bolt
The 3 videos can be slow to appear in this post but there after a couple of minutes
omgimali
Dec 29, 2023 06:35 PM
Atheos
May 2, 2021 12:43 PM
sgvkirbster
Sep 12, 2017 11:52 PM
Kewpie
Mar 30, 2017 09:26 AM
styperchris
Jun 16, 2010 11:57 AM
