Changing transmission fluid
Old Aug 27, 2013 | 03:15 AM
TinyDancer91991's Avatar
Default Changing transmission fluid
I need to know what kind of fluid you guys recommend and how much I need for my 1997 X300 auto trans. I'm obviously an at-home guy so I'm not flushing, just draining and refilling unfortunately. Any advice would surely help!
Cheers!
Old Aug 27, 2013 | 05:43 AM
RJ237's Avatar
You really should replace the filter, also. Any Dexron 3 will work, but I used Mobil 1 synthetic. It took a little over 4 qts with the filter change.
Old Aug 27, 2013 | 06:21 AM
AL NZ's Avatar
Tiny, we thrashed this out a little while ago. there will be some similar threads further down..https://www.jaguarforums.com/forum/x...ightly-101051/
I have followed the repeated part-change approach of our Australian member, who will no doubt post too.
Various sources on the net state total capacity for the ZF 4 speed as 7-10 litres. One ZF spec sheet I found said 7 litres.
I can drain about 3 1/2 litres out of mine, and I have done this 5-6 times in 7 months since buying the car. It changes much more smoothly now.
I use a synthetic ATF - I bought a 20 L drum for a good price.
the correct way of checking the gearbox fluid level is in the manual, and is quite specific - something like this: run the car at least 14 miles, the park on the flat with engine running. Put the lever in all gears then back in Park. Then check the level while still idling.
I find when I pull the dipstick out using this method it comes out dry, then when I re-insert and check again it is spot-on. Can't explain.. but it works.
Old Aug 28, 2013 | 12:23 AM
I kind of thought that was a given, hence why I didn't mention it. lol But thank you for mentioning it anyway, in case I did actually forget.
Old Aug 28, 2013 | 12:28 AM
Fantastic. I was rather fishing for a detailed response such as this one. I don't have the manual, and I've found that searching for some things myself doesn't yield much in the result department. Thank you for the help!
Old Aug 28, 2013 | 05:39 AM
RJ237's Avatar
I think the manual is available in the HOW TO sticky, or you can get the Jaguar Heritage CD on ebay.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
pnwrs2000
Sep 3, 2015 11:55 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
