check engine light troubles
Old Jun 23, 2008 | 07:37 AM
Jaybo242000's Avatar
Default check engine light troubles
Hey folks-
Having some trouble from my check engine light. My 96 xj6 has had the TSB done on the oil drain back assy from the valve cover to what looks like a pcv assy, but actually holds the anti-drainback valve and then connects to the oil dipstick tube, etc. All of that was coming apart, all the rubber was cracked and the valve was clogged up with oil, so I went to Jaguar and got the entire TSB assy kit and installed that, reset the light and it stayed off. The code from the computer was a EGR valve underflow and pcv, as well. I guess this would be the EGR then, I hoped it would be the pcv assy that the TSB was designed for, and the light stayed off for a while, but then back on today. Does anyone have any advice on where to get an EGR inexpensively, has anyone bumped into this same problem? Any help would be greatly appreciated, thanks guys, hope all is well with everyone...cheers!
-James
Old Jun 24, 2008 | 03:29 PM
ken@britishparts.com's Avatar
Default RE: check engine light troubles
Most code readers will pick up the engine codes on cars newer than 1995. They will not read SRS, transmission, or ABS codes for the most part.
TSB refers to Technical Service Bulletin. The manufacturer comes out with these "corrections" once the cars are in the market place. Not all TSB are "recalls."
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
