Chemical Cleaning
Old May 12, 2009 | 11:39 AM
Jack42038's Avatar
Default Chemical Cleaning
Has anyone ever tried running something like b-12 or seafoam through the vacuum lines into the front and rear intakes? Is there anything on the AJ16 that would present a problem for this type of valve cleaning? I've successfully done it before on another vehicle by slowly drawing small amounts of the fluid into the intake with engine running, shutting it off and letting it sit and then restarting the engine and allowing the white smoke to clear.
Thoughts?
Peace!
Jack
Old May 31, 2009 | 09:58 PM
jobooth321's Avatar
I've run seafoam in my gas and once in the oil. No ill effects. I've used it on multiple cars with good results.
My '95 VDP had 85K on the clock when I bought it. I switched it over to Mobil 1 0W-40 and when I did I ran seafoam through the gas and the oil. Been runnin' like a champ since.
Old May 31, 2009 | 10:39 PM
ArmyJag's Avatar
I've used it on my Land Rover Range Rover and it does help. Haven't got around to it yet on the Jag.
jagent
Jun 5, 2022 02:18 PM
Woznaldo
Sep 26, 2015 11:02 AM
driver safz
Sep 26, 2015 06:01 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
BSM
Sep 25, 2015 05:00 PM
