Clock and climate control bulbs
Old Sep 20, 2025 | 03:19 PM
cdma's Avatar
Default Clock and climate control bulbs
Has anyone found a supplier for the bulbs that go in the clock and climate control that are non-LED. I’ve tried LED and they’re just too bright and you can’t dim them.
Old Sep 20, 2025 | 03:53 PM
944play's Avatar
LEDs can be dimmed! The right and hard way is with a resistor. Easy button with Sharpie, black paint, electrical tape, or heat shrink tube.
Old Sep 20, 2025 | 04:55 PM
cdma's Avatar
Yeah I figured. Thanks for the suggestion. Just would like to know if you could get the older ones
Old Sep 20, 2025 | 05:17 PM
PBoudr's Avatar
I used nail polish. It toned them down some and I got used to the brightness quickly. Unfortunately they don't match the radio, but I like the way they look.
Old Sep 20, 2025 | 07:07 PM
Ya Tigor's Avatar
Bulbs can be replaced as bulbs only. All except clock buttons are just have their wire terminals twisted around the base slots. So you just use a needle to pry up the wire, untwist and pull the bulb out. On clock buttons you need to solder the bulbs into the bases. Bulbs a T1.25 shape (4mm diameter) available on eBay. It's said on the clock back that button bulbs are 100mA (1.4W) except hazard 40mA (white cap). Display more looks like 80mA as when i put 100mA into clock display it became brighter than climate display. Caps for T1.25 are available at eBay in different colors.
Old Sep 21, 2025 | 01:21 PM
Parker 7's Avatar
Problem arose with the original incandescent bulbs getting too hot desoldering the ribbon wire connector in the clock I beleive , so the solution was to switch over to LEDs but not perfect
CDMA , you might consider the suggestion of resistor ( you'll have to experiment or know how to calculate to value ) outside the clock and climate control boxes
This is in your area that most of us are not
LED Dimming Guide: A Complete Overview - aspectLED
Old Sep 21, 2025 | 08:19 PM
cdma's Avatar
I am going to give this a shot.
https://a.co/d/5l6yiBn.
Oddman
Apr 24, 2015 06:28 PM
Leaper_Man
Dec 16, 2014 01:09 PM
jagxkrtoofast
May 21, 2012 01:50 PM
mbalce
Oct 30, 2009 05:25 AM
