Co2 sensors
Old Oct 16, 2024 | 08:22 PM
italcarnut's Avatar
Default Co2 sensors
I was wondering if there is a way to bench test CO2 sensors on these cars to install used ones since new ones are either expensive or not available. I can get some from a junk yard, but are they good?
Old Oct 16, 2024 | 09:30 PM
Parker 7's Avatar
There is a process of using a flame heat ( consumes O2 ) and read the resistance after it gets to operating temp
I was never able to do it myself
Videos on Youtube
Remember you are looking for resistance between 2 pins for a Titania based sensor , the other 2 pins are the heater which is required ( you can test cold )
There is a map to installing sensors as the same connectors can be swapped
I have a 4 pin connector map I made several months ago and looking
Do not twist the pigtail wires on removal / installation as very brittle galvanized coated wire , mine had broken wires sticking out the insulation from previous owner
Old Oct 16, 2024 | 09:51 PM
Parker 7's Avatar
Pic on old broke computer , you can match it up with the car side connector as the colors are only valid on car side
jomo
Apr 25, 2024 12:18 PM
Stamford
Sep 19, 2022 06:20 AM
P416
Jul 28, 2022 07:24 AM
ThomasX
Mar 11, 2011 02:37 AM
