Coolant leak
Old Apr 13, 2014 | 08:05 PM
Mfieldpreecher's Avatar
Default Coolant leak
Got a small (for now) coolant leak. Looks to be radiator. I can see coolant has run down the edge of the tubes on the radiator. Seeing that thru the grill because - well you know...you see nothing engine side.
But looks to be 3 "coolers" - or is this just some weird levels? Maybe an oil cooler, super charger cooler, and radiator? Looks to be on the "middle" radiator... Anyone know what I'm looking at?
How difficult is radiator removal? Obviously the fans have to come out ...anything else?
Old Apr 13, 2014 | 08:24 PM
Doug's Avatar
The forward most is the supercharger radiator. Next should be the a/c condenser. Then the actual engine radiator.
I've never had to remove mine so I can't comment with specifics. I know the fans come out easily, though.
After that upper and lower hoses, cooler pipes, then upper radiator moutning panel, then lift radiator out?
Someone has has been there will chime in
arskemp
Sep 21, 2015 02:19 PM
Lannyl81
Sep 19, 2015 08:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
