Cooling Fans
Old Dec 4, 2012 | 06:51 AM
Backtrax's Avatar
Default Cooling Fans
Got a 1997 X300 3.2L. The cooling fans run continuously when the ignition is switched on (with or without the engine running). Have heard this may be result of a mod Jaguar released to cure some other problem. Does anybody know if this is correct and is there a workaround. Seems a bit excessive to have fans running on short journeys in winter!
Old Dec 4, 2012 | 07:18 AM
RJ237's Avatar
Welcome to the forum. Do a search for my thread "cooling fan 95 XJ6" and you will find the explanation.
Have you visited the new member area?
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 4, 2012 | 09:01 AM
sparkenzap's Avatar
Be careful if you decide to change the circuit back. It was done for a reason, which was to prevent blowing the fan fuses.
mikiep
Dec 20, 2019 07:37 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
