Correct idle RPM when in gear?
Old Mar 8, 2018 | 07:17 AM
al_roethlisberger's Avatar
Question Correct idle RPM when in gear?
Curious what the correct idle RPM should be when the car is in gear.
It idles between 700-800 in Neutral or Park, and drops to about 600-700(closer to 600) when in gear, so just checking if that is what is expected.
Old Mar 8, 2018 | 08:53 AM
Lady Penelope's Avatar
See page 80 , your correct :
http://www.jagrepair.com/images/Trai...20-%202000.pdf
Old Mar 8, 2018 | 10:02 AM
Thumbs up
Originally Posted by Lady Penelope
Thanks!
Per the document, which BTW is a VERY helpful reference:
Target stable idle speeds: Park / Neutral – 700 rpm
(normal operating temperature) Drive / R, D 2, D 3 – 580 rpm
Idle speed ± 30 rpm when coolant temperature is less than 86˚F (30˚C)
Idle speed ± 20 rpm when coolant temperature is 86˚F or higher
Old Mar 8, 2018 | 10:35 AM
katar83's Avatar
Isn't 4.0 and 3.2l different when it comes to idle RPM? As far as I remember they are, 3.2l should idle slightly higher than 4.0. Mine definitely did.
kr98664
Jul 13, 2017 06:07 PM
NTL1991
XJ40 ( XJ81 )
Jan 23, 2016 06:05 AM
newguy12
Mar 11, 2013 08:01 PM
calvindoesntknow
Apr 10, 2012 10:11 PM
The Coupe
Mar 28, 2012 08:00 PM
