crank sensor
Old May 12, 2014 | 09:46 AM
mark rock's Avatar
Default crank sensor
Hi
1994 3.2 xj6, bit relluctant to pay £80 for one to find out thats not my problem.
Cheers all mark
Old May 12, 2014 | 10:01 AM
Don B's Avatar
Originally Posted by mark rock
Hi
1994 3.2 xj6,bit relluctant to pay £80 for one to find out thats not my problem.
Cheers all mark
Hi Mark,
What are the symptoms leading you to want to try replacing the CPS or CKPS? Also, is your car an 1994 X300 or a 1994 XJ40?
If you're fairly certain the CPS (XJ40 terminology) or CKPS (X300 terminology) is a prime suspect, I would recommend you fork out for a new one, because it is one of the common causes of sudden no-starts and keeping a spare in the boot/trunk is a good idea anyway.
Cheers,
Don
Old May 12, 2014 | 10:55 AM
Jagfixer's Avatar
There is a test procedure in manual.
Old May 12, 2014 | 03:49 PM
mark rock's Avatar
Originally Posted by Don B
Hi Mark,
Cheers,
Don
Hi Don
Couple of missfires coming home in it.Stalled pulling onto driveway.Tryed to start next day and doesnt want to know.Ive got fuel and spark so i was working on the elimination process.
Cheers Mark
Old May 12, 2014 | 04:35 PM
sparkenzap's Avatar
Does the tach move while cranking?
Old May 12, 2014 | 05:41 PM
Don B's Avatar
Hi Mark,
I see that your signature line shows your car as a '95 - I was confused by your OP.
Ross' question about the tach reading while cranking is the most relevant right now so let us know.
Cheers,
Don
Old Jun 4, 2014 | 02:50 PM
mark rock's Avatar
Just to finish this post.It turned out to be the crank sensor thanks for advice from all im sure i will be back for more in the future..
mrplow58
Jan 21, 2024 05:53 AM
RoyLittle0
May 25, 2023 02:38 AM
Papelione
Sep 21, 2015 06:13 PM
Paulie710
Sep 17, 2015 01:05 AM
joesoap
Sep 10, 2015 01:09 AM
