Cylinder Head
Old Jan 22, 2015 | 03:52 PM
nickhand's Avatar
Default Cylinder Head
is there a difference between the normally aspirated head and SC cylinder head on a 95-97 X300? Thanks Nick
Old Jan 22, 2015 | 05:42 PM
Don B's Avatar
Hi Nick,
According to the Electronic Parts Catalog (EPC), which you can download from this forum, the part numbers for the N/A and SC cylinder heads (less cams and valves) are different:
N/A to engine 128486: NBC2510BA
N/A from engine 128487: NBC2510CA
SC: JLM12075
My assumption would be that the SC head is designed for lower compression than the N/A head, but one of our tech gurus will know for certain.
Cheers,
Don
Old Jan 23, 2015 | 05:44 PM
nickhand's Avatar
Thanks Don ,I had thought the compression ratio was set by the piston choice.If it is controled by the head choice maybe a SC head could be modified to use on a NA engine? Nick
Old Jan 23, 2015 | 06:33 PM
AL NZ's Avatar
Andy and others will know the answer.
I may be the lower SC compression is a mix of both lower piston height/shape, and larger cylinder head volume
I will be interested to find out...
Old Jan 24, 2015 | 01:02 AM
XJRengineer's Avatar
The difference in compression ratio between naturally aspirated AJ16 engines and the supercharged versions was achieved entirely through the design of the piston crown, which was dished on the AJ16 SC engine. After 20 years I can't remember using different cyl heads castings in development, so it must have been quite a subtle / late change. My guess is that higher exhaust valve seat insert material was specified for the SC engine, if the part numbers for the two bare heads are different. In which case, the two heads would be physically interchangeable and the cyl head for an NA engine would probably last on an SC engine unless you were conducting an engine dyno durability test (eg >100hrs running at peak power - not really likely in a car)
Old Jan 24, 2015 | 02:50 PM
nickhand's Avatar
Thanks thats the info I was looking for. I picked up a new in the box sc cylinder head at a good price. It's good to know that it will work on my NA car as well if needed Nick
X308XJR
May 20, 2019 06:50 PM
PhilXJ6
Jan 3, 2016 08:55 PM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
