D.I.Y Front Driver Door Micro Switch And Door Cable Repair!
WARNING WARNING WARNING
I had removed this bolt to get mine apart ( i forgot to roll the window down before removal)
When re installing i could not get it to connect back in there? im completely stumped on wtf i even removed it from
I will post this because it is what i did and i had success ( so far)
Remove this bolt at your own risk
2nd pic is where the square peace sits that the bolt was clamping down
Time to remove the
Micro switch and all the connections
Start with this connection. it just clips on and off. Pull towards yourself and it will come off.
Tips
A) use both hands and do not use a tool you will break or bend it
B) Get ready to cut your forearms have first aid near you
Tips
Now remove the one behind the connection you just disconnected
This one you grab on the black plastic part and PULL DOWN
they will come apart. do not use any tools just use your hands
Install is Reverse
Tips For Install
A) If the Replacement micro switch is in the closed position the door will not shut
To fix this simply install everything! From outside the car hold the door handle open and shut the car while holding the handle up! it will force the micro switch to unlock and let your car door shut
B) Triple check every wire is connected and not int the path of the window regulator
C) Make sure everything works perfect before calling it quits!
Tips For Install
An old post but just to say thank you for posting. Tim his helped me get the lock mechanism out without breaking anything. Also just for anyone else - I managed to get it out without removing the window regulator. It’s a squeeze but possible.
I expected to have to take apart the entire door, but I found my cable break right next to the door handle.
I was able to hack the cable together to the L handle-end with a cable splicing sleeve and crimping tool.
Works for now... curious to see how long it lasts but it only took 1 screw to access (and removing handle wood trim).
cable splicing sleeve:
https://www.farmandfleet.com/product...g-sleeves.html
well, ended up replacing the cable with a new one (other end snapped). this was helpful for connecting it without removing the lock/latch
https://www.jaguarforums.com/forum/x...q-67357/page3/
