Dash light, bulb?
Howdy.
Dash light in tope left corner finally went out. It was on and off for a few weeks .
Any special instructions on removing the gauge cluster and which bulb model should I buy ahead of time. Looking around the forum, I found some instructions.
Unbolt lower panel, few bolts, push the cluster out?
Id like to replace all the bulbs behind the gauges so I dont ever have to do it again.
Id like to fix the fog light switch itself too, the green light inside the switch has fallen in.
Thank you.
Thank you.
