decarbon non-running AJ-16 engine
Old Jan 1, 2014 | 03:59 PM
bliving7's Avatar
Default decarbon non-running AJ-16 engine
How do I decarbon a non-running AJ-16 engine?
bliving7
Old Jan 1, 2014 | 10:18 PM
OK.
Simple answer to the actual question.
Dissmantke the engine and physically remove the carbon.
There is no other way that I know of to do this on a non-runner.
Old Jan 4, 2014 | 04:38 PM
bliving7's Avatar
Default Resolved
Thanks everyone. I got my car to start today after replacing the fouled NGK iridium plugs and doing the transmission fluid trick. One teaspoon per cylinder.
I also talked to a professional mechanic. He thought I had flooded the cylinders with raw gasoline which wiped out the oil film and hence no compression.
I'll never run the engine for just two minutes again. A wonderful lesson learned. I've been driving that car (1995) since new. I should have known better.
Bill Livingston
Hot Springs, AR.
Old Jan 4, 2014 | 07:07 PM
Stiff drinks ALL round, Bills's buying.
GLAD it was soooooo simple.
Old Jan 5, 2014 | 09:12 AM
Spikepaga's Avatar
Bill Livingston
Hot Springs, AR.
I have done it 3. The AJ16's just don't like that. If you are going to move it in the garage to get to another or get out of the way on the driveway, car be prepared to take a 15 minute drive around the block.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
